Header Help - Printable Version
+--- Thread: Header Help (/showthread.php?tid=4961)
Header Help - girard.k - 08-13-2007
first im gonna say...BBQ was awesome can't wait for the next...well done...
Anyways i got some instructions from [FF] that says for the shorty header i need to replace the 10mm studs into the head...Do i actually have to go get some new ones or can't i just use the stock studs...
Header Help - SL8RZZX3 - 08-13-2007
girard.k,Aug 12 2007, 04:04 PM Wrote:first im gonna say...BBQ was awesome can't wait for the next...well done...
[right][snapback]246509[/snapback][/right]
I think that means you have to take them out to get the header IN place, then you put them in to line up the header and the gasket. If you have new header bolts to install, you install them, THEN remove the studs and replace them with the new bolts
Header Help - NikiterZTS - 08-13-2007
u can reuse old ones or u can buy some new from Ford
Header Help - hardk0re - 08-13-2007
Re-Use is fine.
Header Help - Chromey - 08-13-2007
I didnt remove the studs for the install, But it might make it alot easyer if you do.
