Clunking On Front End.... - Printable Version
+--- Thread: Clunking On Front End.... (/showthread.php?tid=5084)
Clunking On Front End.... - ANTHONYD - 07-29-2007
Hey guys, I have a rather annoying clunking in the front end of the car while turning and going over bumps.
Does anyone know what this could be and the difficulty to remedy it????
Clunking On Front End.... - zx5power - 07-29-2007
mines doing it to took it to dealer , everythings tight dunno what it is ...
Clunking On Front End.... - tippmann - 07-29-2007
i heard a clunking sound when my coils were broken, but only when i turned or would go over a bump
Clunking On Front End.... - konafocuswrc - 07-29-2007
i m having same problem.,
it is strut mount problem..the center nut thing got loose over time..
but once i get it replaced, i will know for sure.
Clunking On Front End.... - Frost__2001 - 07-29-2007
in my case when I heard that it was the stablizer arm on the passenger side that was fubared...
if you can tell what side it's from pop of your front tire and see if anything is broken.
Clunking On Front End.... - Mason - 07-29-2007
konafocuswrc,Jul 28 2007, 04:53 PM Wrote:i m having same problem.,
[right][snapback]245082[/snapback][/right]
Could be. Also could be somthing simple. Swaybar links for example.
Clunking On Front End.... - vealzx3 - 07-29-2007
Your endlinks are toast. Cheap part and an easy fix.
Clunking On Front End.... - j3rt - 07-29-2007
Ditto, I had mine tightened up while at the Fast Lane.
I'd pop the hood and check them out, compare torque, etc.
Clunking On Front End.... - Scorpion - 07-29-2007
Swaybar endlinks, or connectors as the book calls them. Almost definitely these. They only need to be a little worn to make a lot of noise over bumps etc. I did mine, and it fixed it.
Clunking On Front End.... - zx5chris - 07-29-2007
turn each wheel and pull the stabilizer end links outwards, if they move, replace them. easy fix.
Awesome guys. I'll have a look this afternoon!
Clunking On Front End.... - NOS2Go4Me - 07-30-2007
I had a squeak/groan that was endlinks, but they have been known to clunk as well.
Good luck bud!
Clunking On Front End.... - Scorpion - 07-30-2007
NOS2Go4Me,Jul 29 2007, 09:15 PM Wrote:I had a squeak/groan that was endlinks, but they have been known to clunk as well.
Good luck bud!
[right][snapback]245129[/snapback][/right]
Ya, mine did the clunk thing. Drove it around for 2 months like that, but in the end it got too annoying. Didn't take long to do the fix.
Clunking On Front End.... - Flofocus - 07-31-2007
Could be a cv boot that is cracked to (easy to check), but I'd d start with the endlinks. Theres a reason I keep spares at home ;) :lol:
