Air Condition Problem (recirculate Button) - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Air Condition Problem (recirculate Button) (/showthread.php?tid=5392) Pages:
Air Condition Problem (recirculate Button) - awang44 - 06-19-2007 hi all, I have a 01 focus wagon. I notice that when the recirculate button is on the gain on air flow is not noticeable. also, I can still smell odor. basically the recirculating button does not function at all. it's not a major problem. But the air condition is not cold now and like I said i can smell other people's exhaust. What should I be looking at to fix this problem? Thanks Air Condition Problem (recirculate Button) - NefCanuck - 06-19-2007 Well, if you're saying that there is no measurable decrease in the temperature coming from the vents with the A/C on, I think you have some pretty major A/C issues (Which could be anything from the refridgerant leaking out, to the A/C compressor dying, to the A/C clutch becoming inoperative) IOW, its dealer time (or private mechanic, if you're lucky enough to know one who has modern A/C servicing equipment. NefCanuck Air Condition Problem (recirculate Button) - Frost__2001 - 06-19-2007 one thing Nef didn't mention was, you could be out of CFC in your A/C making it seem like it's not getting cold enough, or it's just blowing out warm air. Usually you have to recharge it like every 5 years or so? as for the smell it could be the interior air filter that could be bad. Air Condition Problem (recirculate Button) - awang44 - 06-19-2007 Thanks for all response. sorry for not being clear. when i turn the A/C on and recirculating off, it blows cold air. When I turn the A/C on and recirculating on, it feels the same as A/C on recirculating off. no significant gaining on air flow and coldness. My last refill was last year. just I remember all the cars that I driven before, when I have A/C ON and recirculating ON, it always seem cooler and more air flow, And no odor from outside. Air Condition Problem (recirculate Button) - Focus man. Focus. - 06-19-2007 I would check the cabin air filter which is under the black plastic trim between the hood and the wipers on the passenger side accesible by removing the trim pannel from the exterior of the car. I will see if I can find the How-To for it. You can get it in here. Focus Canada How To's Air Condition Problem (recirculate Button) - awang44 - 06-19-2007 I don't have a filter there. I didn't came with one and I never bother put in one. I am worry about if any mechanics of the recirculation is bad. or the button. Air Condition Problem (recirculate Button) - OAC_Sparky - 06-19-2007 awang44,Jun 18 2007, 04:29 PM Wrote:I am worry about if any mechanics of the recirculation is bad. or the button.If you don't hear the damper switch over, one or the other is likely a problem. Air Condition Problem (recirculate Button) - Scorpion - 06-19-2007 Yes, you 'should' hear a slight 'thump' as the damper (large flap type valve) moves from one position to the other. If not, it could be stuck, or the motor/solenoid has failed. If the recirc light comes on, I'd check the damper first. (And sparky, you ARE a SB! :lol: ...or were you just pointing out the obvious? :lol:) S. Air Condition Problem (recirculate Button) - mo_focus - 06-19-2007 http://forums.focaljet.com/team-tech/54044...irculate+Button try this maybe it works, RECIRC is only operational if you have the air going through the panel and/or floor vents. So, even if you try hitting the button when you are defogging/defrosting your front windshield, it will not light. Air Condition Problem (recirculate Button) - OAC_Sparky - 06-19-2007 ^^ Yes, that's true. I forgot about that. Me, a SB?? Sarcasm never crossed my mind. :ph34r: Air Condition Problem (recirculate Button) - Mason - 06-19-2007 awang44,Jun 18 2007, 04:29 PM Wrote:I don't have a filter there. I didn't came with one and I never bother put in one. Get one of those. Thats probibly why your smell other peoples cars. Air Condition Problem (recirculate Button) - awang44 - 06-19-2007 The light does come on. the air flow is on floor or panel. but i don't hear the damper moving when i hit the switch... so the problem should be that damper thing... How do I check it??? Air Condition Problem (recirculate Button) - oldeguy - 06-21-2007 Is there a fuse for this? If so, it might be a fuse problem Air Condition Problem (recirculate Button) - Spinal - 06-21-2007 what exactly does the recirculate button do? Air Condition Problem (recirculate Button) - oldeguy - 06-22-2007 Spinal,Jun 21 2007, 09:49 AM Wrote:what exactly does the recirculate button do?It closes off a vent so you don't bring in warmer air from outside, so your air conditioner will run cooler. Air Condition Problem (recirculate Button) - Spinal - 06-22-2007 does it burn anymore gas? and im assuming its a good idea to keep it on all the time? Air Condition Problem (recirculate Button) - awang44 - 06-26-2007 I don't think it will burn more gas since the air in the cabin is already cooler then outside, in summer when you need the air con on. The compressor doesn't have to work as hard as cooling down the hot air from out side. I guess the only negative is when you have it on for too long, oxygen is consumed by passengers then you might feel a bit discomfort. but again I don't think Focus is that air tight. It should be ok to keep it on all the time. So... anyone had idea how it works? Air Condition Problem (recirculate Button) - Mason - 06-26-2007 Windows will some times fog or get condensation on them if you leave it on for a really long time. Air Condition Problem (recirculate Button) - awang44 - 06-26-2007 I thought it would be the opposite since moisture inside are constantly being sucked out every time the air is recycled. I may be wrong. Mason,Jun 25 2007, 03:18 PM Wrote:Windows will some times fog or get condensation on them if you leave it on for a really long time. Air Condition Problem (recirculate Button) - NefCanuck - 06-26-2007 awang44,Jun 25 2007, 11:05 AM Wrote:I thought it would be the opposite since moisture inside are constantly being sucked out every time the air is recycled. I may be wrong. But as the glass cools inside, the outside of the glass is still getting warmed up. This can lead to condensation outside the window, requiring the occasional wipe with teh windshield wipers to get rid of it. NefCanuck |
