Rusted Out - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Rusted Out (/showthread.php?tid=5495) |
Rusted Out - oldeguy - 06-06-2007 The bottom two bolts of the exhaust manifold heat shield, that piece of aluminum that is bolted to the exhaust manifold, have rusted out. The top two bolts are still fine. My question is, can I just remove the shield without having any serious heat issues inside the engine bay? Rusted Out - redZX3 - 06-06-2007 I took mine off and it gets F*ckin hot in the engine bay....I am not sure if it got that hot before or not, so I cant really say. I would say " give it a go " Rusted Out - NikiterZTS - 06-07-2007 taking it off wouldn't benefit you anything good.....but it will make it hotter, keep it if you can Rusted Out - Mason - 06-07-2007 oldeguy,Jun 6 2007, 08:45 AM Wrote:The bottom two bolts of the exhaust manifold heat shield, that piece of aluminum that is bolted to the exhaust manifold, have rusted out. The top two bolts are still fine. My question is, can I just remove the shield without having any serious heat issues inside the engine bay? Well it should be replaced. BUT ford calls it a Carb Cover for some reason.... And its no fun getting those bolts out either. Trust me :lol: |
