Suspension Queries - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Suspension Queries (/showthread.php?tid=55) |
Suspension Queries - StreetEdition - 04-19-2010 Hi All Forgive me for the newb questions... First, I have a 06 ZX5 SES So, I recently got a great deal on Eibach Sportlines. I'm quite stoked. I understand that I should be replacing the stock shocks/struts (aka dampers?) My car is only a DD. I mainly drive to and from work. Do I *need* super duper replacements? What are my options? Suspension Queries - ZTWsquared - 04-19-2010 StreetEdition,Apr 19 2010, 02:19 AM Wrote:Hi AllThe "problem" with sportlines is that your suspension will be bottoming out on a regular basis - especially if you're in the GTA - you and your struts will take something of a beating. Your stock struts won't last very long and then you will be faced with another suspension job - better IMO to replace the struts with suitable replacements at the same time you put in the springs. Eibach obviously makes a strut for that application, and based on what I've read, the only strut that Ford makes that can take that kind of a beating is the ones made by Multimatic - called the Dynamic Suspension struts - and they aren't cheap. I lowered my ZX5 just in January with the FRPP DYnamic springs and I put in a set of SVT struts that I had lying around (yes, I have whole suspensions lying around LOL) and one of them is borked already - just not enough travel. So, because this is a track car and some of the older tracks like Mosport and Watkins Glen can be bumpy in places, I am replacing the springs with a set of SVT - raising the car by a good inch probably - and a fresh set of SVT struts. Suspension Queries - castone - 04-19-2010 ^^^What he said! ;) I had the Sportline's and Eibach dampers, but the dampers only lasted about 5000 km's. :angry: I'm now running KYB AGX's with no issues yet :D Suspension Queries - Jmountney1 - 04-19-2010 how did ur guys struts only last that long. on my zx3 with ebay coil over things all the way down(wayyy lower than sport lines) i never blew my struts in the 60000km i put on them? obviously it is a better idea to put the struts that were ment for the sport lines but if hes talking 1.5 drop i think he will be just fine. Suspension Queries - GFXjamie - 04-19-2010 well i had a prokit with stockers and the stock dampners lasted me a year from brand new before they blew. upgrade, i went with kyb's AGX, GR2 will do aswell, just not as good... Suspension Queries - Oscar The Grouch - 04-20-2010 Prokits on for 2 years, shocks went downhill. Went to a full retrofit with Eibach Swaybars, Tokico D-Spec Adjustable shocks, tubular control arms, etc. Basically there's no stock suspension items left except for the front toe arms. Suspension Queries - StreetEdition - 04-20-2010 thanks for info guys, much appreciated ... The sportlines apparently give at minimum a 2" drop, so I really dont want to take a chance and have to replace the OEM/stock parts a few weeks/months later. I am not planning on doing auto-x or any race stuff.. My car is just a DD gfxjamie >> what could i expect if I decided to go with the kyb gr2? Suspension Queries - Gabriel - 04-20-2010 It's best to install springs and dampers that are made for each other . I know it sounds 'romantic ' :D , but I found out that my original SVT struts went in the first 3-4 months after installing lowering springs . Just like Ken said , not enough travel . |
