How Much Power Does Pzev Intake Rob? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: How Much Power Does Pzev Intake Rob? (/showthread.php?tid=5526) |
How Much Power Does Pzev Intake Rob? - 2FST4U - 06-02-2007 I looked a little close at my ZX4ST and see that it has the PZEV air box. I assume this because of that guage thingy on the side of it. Just curious how much of a gain is to be had with a cold intake? Does installing one void my warranty? Thanks. How Much Power Does Pzev Intake Rob? - euro_zx5 - 06-02-2007 The gauge just shows how much air the filter is allowing in. Basically a gauge to indicate when to replace the box/filter. And all the newer Focus' have them. (05+ I believe) Intakes are good for a few hp, and should not void the warranty. If you do go to the dealer, it's as simple as removing it temporarily if the particular dealer you go to has a problem with it, just ask them in advance. How Much Power Does Pzev Intake Rob? - ANTHONYD - 06-02-2007 2FST4U,Jun 2 2007, 02:15 AM Wrote:I looked a little close at my ZX4ST and see that it has the PZEV air box. I assume this because of that guage thingy on the side of it. Just curious how much of a gain is to be had with a cold intake? Does installing one void my warranty? Thanks. Cold air intakes won't void your warrenty as long as ist doesn't cause a problem directly related to the intake. A cold air intake usually adds "Few" extra ponies. Defintely one of the best bangs for your buck mod wise. I'm not to familiar with the PZEV set you have (I have a ztech) maybe one of the other bobble-heads around here will know more. :P How Much Power Does Pzev Intake Rob? - euro_zx5 - 06-02-2007 ANTHONYD,Jun 2 2007, 07:34 AM Wrote:2FST4U,Jun 2 2007, 02:15 AM Wrote:I looked a little close at my ZX4ST and see that it has the PZEV air box. I assume this because of that guage thingy on the side of it. Just curious how much of a gain is to be had with a cold intake? Does installing one void my warranty? Thanks. Only difference between the regular and pzev motors, relating to the air box is a separate breather hose. FocusSport.com shows the difference: http://focussport.com/coolflo.htm How Much Power Does Pzev Intake Rob? - ZTWsquared - 06-02-2007 The only way your car could be a PZEV car is if it's originally from California - and it would have a PZEV badge on the rear. The early PZEVs were 2.3 Duratecs with just 130 hp ... that changed significantly in '05 at which point IIRC the PZEVs had essentially the same power as the non-PZEVs. Bottom line: installing a CAI on an early PZEV would probably net you some big gains - later PZEVs probably much the same as a normal Duratec. 2FST4U,Jun 2 2007, 02:15 AM Wrote:I looked a little close at my ZX4ST and see that it has the PZEV air box. I assume this because of that guage thingy on the side of it. Just curious how much of a gain is to be had with a cold intake? Does installing one void my warranty? Thanks. How Much Power Does Pzev Intake Rob? - torradan - 06-03-2007 Your ST doesn't have a 2.3l PZEV. I didn't even know they had the PZEV motor up there. Down here its only required in 4-5 states, and of course NY is one of them. :angry: My 05 2.0l is a PZEV, but my buddy's ST is a normal 2.3l. They share the airbox, but thats the end of it.. the 2.0 has a few extra hoses running around for the emissions garbage. Rip that box out, and put a CAI on.. you'll notice a difference. It won't void your warranty either unless you turn the car into a submarine and suck in water. But I think you'd have some bigger issues to deal with if you did that. How Much Power Does Pzev Intake Rob? - NOS2Go4Me - 06-03-2007 The 2.3L has been proven to make no less than 8 more WHP with a true CAI. With a SRI, it's normally at least 5WHP more. You'll be MUCH happier with a new intake on there. :D How Much Power Does Pzev Intake Rob? - NefCanuck - 06-03-2007 When I popped the SRI on my 2.0L Duratec and got rid of that horrific lunchbox of suck, together with the MBRP I netted 5WHP and a much improved throttle response over stock, which always had a nasty pause when I stood on it... NefCanuck |
