Rim Offset + Diameter - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Rim Offset + Diameter (/showthread.php?tid=5823) |
Rim Offset + Diameter - gfxman07 - 05-01-2007 Hi all I had a 00 zx3 and had a set of Team Dynamic Racing monza 17 on it ,got them with the car back then right outta the showroom , If any one can tell me what the standard offset is and if there 4 - 100 's or 4-108's and would they fit my new 07 GFX roller ????.please get back to me via email at zx3.guy@sympatico.ca Thanks in advance Matt Roosevelt B) B) B) B) Rim Offset + Diameter - Focus man. Focus. - 05-01-2007 The bolt pattern is the same. I believe the only difference is the diameter of the front brakes. On the earlier modles you can use a 14" wheel and tire combo for snow tires but on the newer version the front brakes will hit the rims if you use that set up. But I think you should be able to make your swap without any issues. Rim Offset + Diameter - gfxman07 - 05-02-2007 Focus man, Focus.,May 1 2007, 12:41 PM Wrote:The bolt pattern is the same.ÃÂ I believe the only difference is the diameter of the front brakes.ÃÂ On the earlier modles you can use a 14" wheel and tire combo for snow tires but on the newer version the front brakes will hit the rims if you use that set up.ÃÂ But I think you should be able to make your swap without any issues. Hi I need the numbers ??? I don't have a clue to which one's they are. LOL getting there soon and a new set of chromy 18's I hope too . Thanks in advance ... P.S. the stiffer the pickle the straighter the line .(LOL) Cheer's Matt Roosevelt B) B) B) B) Rim Offset + Diameter - thenorm - 05-03-2007 bolt pattern for all Focus 4x108 stock offset is around +50mm (depending on model) anything from +42 to +52mm offset should be fine with no rubbing Rim Offset + Diameter - gfxman07 - 05-17-2007 thenorm,May 2 2007, 09:31 PM Wrote:bolt pattern for all Focus 4x108 Thank you so much good fellow focy owner matt r :D :D :D |
