How To Take The Injector Bar(with All 4 Injectors) - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: How To Take The Injector Bar(with All 4 Injectors) (/showthread.php?tid=5851) |
How To Take The Injector Bar(with All 4 Injectors) - NikiterZTS - 04-28-2007 can anybody tell me what i have to do to take out that bar with all 4 injectors in it? thanks How To Take The Injector Bar(with All 4 Injectors) - hardk0re - 04-28-2007 http://www.fordcds.com download it. burn it. install it. use it. How To Take The Injector Bar(with All 4 Injectors) - NikiterZTS - 04-28-2007 aaah i just need a quick answer How To Take The Injector Bar(with All 4 Injectors) - bluetoy - 04-28-2007 Unbolt the fuel rail from the intake. Disconnect fuel lines using a disconnect tool (watch out for fuel spray). disconnect fuel pressure sensor. Lift off fuel rail, might be a little sticky. It is only pressed over O-rings on the injectors. Injectors may or may not come out with rail. They are also just pressed in the intake. If you don't know how to do this then maybe you should get someone who does know to do it for you. How To Take The Injector Bar(with All 4 Injectors) - bigman - 04-29-2007 i had to use a flat head screw driver and pry HARD to get mine out. i lubed the Orings up and it slid right back in. How To Take The Injector Bar(with All 4 Injectors) - NikiterZTS - 04-29-2007 hey guys i ended up getting it out....now i have a problem with the harness How To Take The Injector Bar(with All 4 Injectors) - euro_zx5 - 04-29-2007 NikiterZTS,Apr 28 2007, 11:19 AM Wrote:hey guys i ended up getting it out....now i have a problem with the harness ...and this problem would be...? How To Take The Injector Bar(with All 4 Injectors) - bigman - 04-29-2007 i took the harness out first. made removal super easy man. |
