Bad Dpfe - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Bad Dpfe (/showthread.php?tid=6013) |
Bad Dpfe - oldeguy - 04-13-2007 Does anyone know what the symptoms of a bad DPFE are? I understand that it takes forever for the thing to throw a CEL. Emissions test this year, so no by-pass for me. Bad Dpfe - zx5chris - 04-17-2007 DPFERG sensor monitors the integrity and flow of the EGR system. The sensor usually fails when it get contaminated with water. Pull of the sensor and tap it against a hard surface and look for water. If there is water just replace the sensor. Check with the local dealer, with you VIN there might be a recall for you car, if you aren't over milage or time. There is a modification to move the sensor with longer tube to help prevent the water from reaching the circuit board in the sensor. Good luck :) Bad Dpfe - zx5chris - 04-17-2007 oh by the way it will activate the EGR valve and cause rough running at idle, & the check engine light will turn on. Bad Dpfe - imack - 04-17-2007 In my case, the symptoms were stumbling/hesitation at all speeds, which got progressively worse over the course of a work week (Mon - Fri). On the way home from work on the Friday, the CEL finally came on. Bad Dpfe - ANTHONYD - 04-17-2007 Chugging poor gas milage and hesitation. It's scary for a bit. Unfortunately, you kinda have to drive it until it throws the CEL. Part is about 60 bucks from the dealer. |
