Oil Filter - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Oil Filter (/showthread.php?tid=6059) |
Oil Filter - oldeguy - 04-09-2007 I went and bought a K&N Oil Filter for my next oil change. I looked at it before puttimg it on,and noticed it looked larger than the one I have on the car now. I checked the product code on K&N's website, and it seems that the oil filter I have fits the SPI. My question is, will it fit on the Zetec? Oil Filter - Mason - 04-09-2007 oldeguy,Apr 9 2007, 07:59 AM Wrote:I went and bought a K&N Oil Filter for my next oil change. I looked at it before puttimg it on,and noticed it looked larger than the one I have on the car now. I checked the product code on K&N's website, and it seems that the oil filter I have fits the SPI. My question is, will it fit on the Zetec? Is there one listed for the Zetec on their site? It might not make a difference. Ill check when I get to work tonight for ya. Oil Filter - hardk0re - 04-09-2007 The one for the zetec has the code: 2009, if thats the one you have it should be fine. Oil Filter - mo_focus - 04-09-2007 According to the site SPI and Zetec have the same filter. http://www.goairfilters.com/search_result....x=23&Submit.y=9 sometimes the filter is a bit longer then stock, that shouldnt be a problem as long as the tread size is the same. Oil Filter - Alec Brandon - 04-09-2007 My question is, how much did you pay $$$ for the K&N oil filter veruses a standard Ford brand filter? Oil Filter - hardk0re - 04-09-2007 K&N filters are ~ 13 on sale, ~18 regular price. Oil Filter - oldeguy - 04-09-2007 Alec Brandon,Apr 9 2007, 08:57 AM Wrote:My question is, how much did you pay $$$ for the K&N oil filter veruses a standard Ford brand filter?I'm trying it for the first time, also using amsoil 5w20. Paid $17.00 for the filter. I abuse my Focus daily, so when I can, I give it a better quality of "life" Oil Filter - oldeguy - 04-09-2007 hardk0re,Apr 9 2007, 08:45 AM Wrote:The one for the zetec has the code: 2009, if thats the one you have it should be fine.I checked the K&N site. According to it, the 2009 is for the SPI, the Zetec is right filter is the 1012. I've called the dealer wher I bought the filter, and he is ordering the 1012 for me. I'm going to assume that the 2009 will work too, because I do believe that your ZX3 is running Oil Filter - mo_focus - 04-09-2007 just an FYI, there was a guy at another ford site and he did an extensive testing on the oil filters and his conclusion was that most of them are just names are different, but the actual filter is the same. I'll try to find the site for ya. I usally buy my filters right from the dealer and cost me less then 8$. EDIT* my bad it was actualy Mopar guy that did the test, but here are his results. http://minimopar.knizefamily.net/oilfilterstudy.html Oil Filter - Spinal - 04-09-2007 where did you get the K&N filter? Oil Filter - oldeguy - 04-09-2007 Spinal,Apr 9 2007, 09:57 AM Wrote:where did you get the K&N filter?NAPA Oil Filter - Mason - 04-10-2007 oldeguy,Apr 9 2007, 09:59 AM Wrote:Spinal,Apr 9 2007, 09:57 AM Wrote:where did you get the K&N filter?NAPA Partsource. The K&N filter is really only a good idea if your using full synth oil. Other wise its kind of a waste. Oil Filter - Spinal - 04-10-2007 Mason,Apr 9 2007, 09:49 PM Wrote:i see, i'll look into both stores since they're right beside my house lol. and im using mobil1 5w30 so its all good.oldeguy,Apr 9 2007, 09:59 AM Wrote:Spinal,Apr 9 2007, 09:57 AM Wrote:where did you get the K&N filter?NAPA Oil Filter - Mason - 04-10-2007 I like mobil one. A shame U coulda got your oil at half price for Quaker State full synth. Was down from 38$ for 4.4L to 17$. ended 2 days ago. Needless to say I wont need to buy oil for quite a while. :lol: Oil Filter - Spinal - 04-10-2007 Mason,Apr 10 2007, 07:50 AM Wrote:I like mobil one. [right][snapback]234039[/snapback][/right]where can you get mobil1 oil filters, i looked around but couldn't find any. Oil Filter - Mason - 04-10-2007 Spinal,Apr 10 2007, 09:38 AM Wrote:Mason,Apr 10 2007, 07:50 AM Wrote:I like mobil one. [right][snapback]234039[/snapback][/right]where can you get mobil1 oil filters, i looked around but couldn't find any. The states I beleive. I cant order them through my work either. Oil Filter - oldeguy - 04-11-2007 Update on the Oil Filter. K&N oil filter, 1012 is not available thru NAPA. The 9002 will fit on the Zetec though. Perhaps Partsource carries the 1012? Oil Filter - hardk0re - 04-12-2007 Looks like the 2009 is just a little bigger? HP-2009 Product Specifications Product Style: Oil Filters Height: 5.14 in (131 mm) Outside Diameter: 3 in (76 mm) PSI Relief Valve: (Yes) 8-11 Anti Drain Back Valve: Yes Style: Canister Weight: 0.8 lb (0.3 kg) Product Box Length: 3.15 in (80 mm) Product Box Width: 3.15 in (80 mm) Product Box Height: 5.14 in (131 mm) HP-1012 Product Specifications Product Style: Oil Filters Height: 4.75 in (121 mm) Outside Diameter: 2.97 in (75 mm) PSI Relief Valve: Yes Anti Drain Back Valve: Yes Style: Canister Weight: 0.9 lb (0.4 kg) Product Box Length: 2.95 in (75 mm) Product Box Width: 2.95 in (75 mm) Product Box Height: 5.17 in (131 mm) Oil Filter - oldeguy - 04-12-2007 I don't know either, but, as I said, according to K&N, there are two different filters. Next time, I'll pick up the 9002. I traded in at the NAPA in Bowmanville for two of the NAPA Gold. |
