Power Steering Fluid. (filling) - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Power Steering Fluid. (filling) (/showthread.php?tid=6127) |
Power Steering Fluid. (filling) - ANTHONYD - 04-03-2007 Can I just unscrew the top of the bottle and fill the fluid under the hood? Is it a charged line? I don't need to bleed lines and s*** do I? Power Steering Fluid. (filling) - oldeguy - 04-03-2007 ANTHONYD,Apr 3 2007, 09:27 AM Wrote:Can I just unscrew the top of the bottle and fill the fluid under the hood? Is it a charged line?Unscrew the cap and fill her up. If it is really low, that may be the whining noise you hear. Mine has a slow leak, probably from wrestling the resevoir around when working on the alternator, etc. Something to fix during the warm weather, if it ever gets here Power Steering Fluid. (filling) - mpcv2000 - 04-03-2007 It's just a reservoir like the brake( clutch ) oil reservoir between the firewall and the air box.No pressure in there. You need to add some ? It's must be leaking somewhere , this thing can't evaporate.. Power Steering Fluid. (filling) - ANTHONYD - 04-04-2007 Cool. I'm pretty sure it's NOT the cause for the whining noise. Would low power steering cause flickering and dimming of lights? Power Steering Fluid. (filling) - Flofocus - 04-04-2007 ANTHONYD,Apr 3 2007, 11:04 AM Wrote:Cool. yes, escpecially when its low. When i swapped my new engine in, the car would whine a bit when turning the wheel to its max position. I had Ford bleed the power steering and my problem was gone. Power Steering Fluid. (filling) - mpcv2000 - 04-04-2007 ANTHONYD,Apr 3 2007, 11:04 AM Wrote:Would low power steering cause flickering and dimming of lights? I don't think so , my lights a flickering on my 00 ZX3 and can't figure out what is causing that... I cleaned all ground that I was able to find and no amelioration... :( Power Steering Fluid. (filling) - darkpuppet - 04-04-2007 um.. my focus, and even the stang will often experience flickering lights and whatnot when idling. Anyways, just top up the steering fluid.. there's a max fill line you don't want to go above and that's about it. Power Steering Fluid. (filling) - oldeguy - 04-04-2007 ANTHONYD,Apr 3 2007, 11:04 AM Wrote:Cool.Your right, the low fluid won't cause the flickering and dimming, but, the low fluid makes the pump work harder, and the pump will whine. Regardless, the fluid is just a top up, no bleeding or pumping needed. Power Steering Fluid. (filling) - paolo - 04-04-2007 my ac compressor went bunk and that caused my lights to flicker when idling... but my resovoir was low too so i did top it off just incase ya know... |
