How To Remove Paint Transfer - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Appearance (//www.focuscanada.net/forum/forumdisplay.php?fid=21) +---- Forum: The Detailing Bay (//www.focuscanada.net/forum/forumdisplay.php?fid=13) +---- Thread: How To Remove Paint Transfer (/showthread.php?tid=6174) |
How To Remove Paint Transfer - laidman - 03-31-2007 So before christmas I managed to head butt a garbage bin woth the front corner (passenger side) of my car. No damage, just paint transfer off the bin onto my car. Its going to be nice tomorrow, so I figures its a good day to fix this blemish. I was origonally able to buff out some of the paint, but also took away the shine from the paint on my car. So anywho, how do I take care of this problem, products to use, cost involved. What I do have is an oscillating buffer, and thats about it. Please help a brotha out. How To Remove Paint Transfer - Mason - 04-01-2007 laidman,Mar 30 2007, 11:03 PM Wrote:So before christmas I managed to head butt a garbage bin woth the front corner (passenger side) of my car. No damage, just paint transfer off the bin onto my car. Its going to be nice tomorrow, so I figures its a good day to fix this blemish. MR.Clean magic erasers are good for getting off hard to remove stuff. Ive use it to get tar off the side of my car. give it a try. How To Remove Paint Transfer - laidman - 04-01-2007 I picked up this Liquid claybar stuff. It talks about removing what I want so I will try it. Today was s***, so Maybe another day How To Remove Paint Transfer - ANTHONYD - 04-01-2007 Try several passes with a clay bar. That should do the trick. If not, get some rubbing compound and a rag with a little water and elbow grease. The compound will pretty much "grind" it off. Then wax with a cleaner and clear coat carnuba. It should take you about half an hour to do it properly. *** Mason, using a Mr.clean magic eraser is probably the equivilant of dragging a sponge that layed in you garden all winter over the paint.*** How To Remove Paint Transfer - reldridge - 04-02-2007 I used a Mother's clay bar and Meg's ScratchX to remove black paint transfer off my inlaws white Century. And they were going to take it to the body shop to have it resprayed... :D Ryan How To Remove Paint Transfer - laidman - 04-02-2007 does it matter if te car has a metalic paint, or does this stuff only apply to base colours I have the Copper metallic Focus, I just want to make sure that I don't make it any worse... How To Remove Paint Transfer - ANTHONYD - 04-02-2007 You won't make it any worse. Just don't use a high-speed buffer with the compound. Do it by hand. How To Remove Paint Transfer - ashhabib - 04-19-2007 Get scratch Doctor, it should take it out easily without too much work. Also, it doesn't take the shine out of your car How To Remove Paint Transfer - thenorm - 04-20-2007 I use a polishing wax to remove the scuff marks from cones that i hit at auto-x. I assume that it would work the same as on the paint transfer. And it wont damage your metallic paint. most scratches or blemishes only affect the clear coat, unless they are very deep. How To Remove Paint Transfer - Flofocus - 04-20-2007 mothers clay bar always took off the yellow paint from the street painters on my cars. |
