M Sport S2000 Fiesta - Printable Version
+--- Forum: Motorsport (//www.focuscanada.net/forum/forumdisplay.php?fid=20)
+--- Thread: M Sport S2000 Fiesta (/showthread.php?tid=635)
M Sport S2000 Fiesta - ZX3_2NV - 11-21-2009
[Image: untitled-3.jpg]
Ford Fiesta S2000 Technical Specification
Engine: Ford 1998cc Pipo built I4 Duratec S2000 engine. Four cylinders, 16 valves. Bore 87mm. Stroke 83mm. Cosworth electronics engine management system. Catalytic converter.
Power: 280 bhp at 8000 rpm.
Torque: 260 Nm at 6500 rpm.
Transmission: Permanent four-wheel drive. M-Sport / Xtrac six speed sequential gearbox with AP clutch.
Suspension: Front and rear: MacPherson struts with Reiger external reservoir dampers, three-way adjustable. Fully adjustable fabricated steel links. Front and rear anti-roll bars. Machined aluminium uprights.
Brakes: Gravel (front and rear): 300mm Brembo ventilated discs with Brembo four piston monoblock calipers.
Asphalt (front ): 355mm Brembo ventilated discs with Brembo four-piston monoblock calipers.
Asphalt (rear ): 300mm Brembo ventilated discs with Brembo four-piston monoblock calipers.
Hydraulic handbrake.
Steering: Power-assisted high-ratio (12:1) rack and pinion. One and a half turns lock to lock.
Wheels: Gravel: 7in x 15in (aluminium) wheels with 650mm tyres.
Asphalt: 8in x 18in (magnesium) wheels with 650mm tyres.
Bodyshell: Unitary construction. Unique composite side panels. Welded T45 steel safety roll cage. Aerodynamic rear wing. Unique front 'bumper' treatment.
Electronics: Full Cosworth electronics data acquisition for on-event diagnostics and performance development.
Fuel tank: FIA FT3 tank, 80 litre capacity, located centrally.
Dimensions: Length: 3958mm. Width: 1820mm. Wheelbase: 2489mm. Weight: 1200kg minimum.
Check out there site Here
and look at M Sport Rally Cars for sale Here. I would so be importing something from there if I won the lottery.
M Sport S2000 Fiesta - reldridge - 11-21-2009
hot hot hot hot hawt. HOT.
I'd DD the cr@p out of it...
