Water Pump #@$%^^&& - Printable Version
+--- Thread: Water Pump #@$%^^&& (/showthread.php?tid=6387)
Water Pump #@$%^^&& - oldeguy - 03-13-2007
Okay ladies and gentlemen, I'm starting to hear a bit of a rattle in the engine. It's not bleeding green, yet.I'm thinking it's the water pump. How $%$%^%@$#@ hard is it to replace, by a do-it yourselfer, and what's the cost of a rebuilt?
Water Pump #@$%^^&& - redZX3 - 03-13-2007
oldeguy,Mar 13 2007, 01:48 AM Wrote:Okay ladies and gentlemen, I'm starting to hear a bit of a rattle in  the engine. It's not bleeding green, yet.I'm thinking it's the water pump. How $%$%^%@$#@ hard is it to replace, by a do-it yourselfer, and what's the cost of a rebuilt?
[right][snapback]230126[/snapback][/right]
Its a pain in the ass to relace yourself....its not worth it to get it rebuilt, they are cheap enough to just buy a new one.
Water Pump #@$%^^&& - ZED_not_zee - 03-13-2007
My best friend is a hayns manual... it helps alot and it was the best christmas present ever!!! not knocking you! I just used to fix my car without one and it makes such a diffrence
Water Pump #@$%^^&& - ZX5focused - 03-13-2007
ZED_not_zee,Mar 13 2007, 02:04 AM Wrote:My best friend is a hayns manual... it helps alot and it was the best christmas present ever!!!  not knocking you!  I just used to fix my car without one and it makes such a diffrence
[right][snapback]230173[/snapback][/right]
i just picked one up :)
Since I always buy a used car. the route home from the car dealer is to the nearesrt Canadian Tire to pick up a Haynes. My library of manuals is bigger than any other part of my library.
Water Pump #@$%^^&& - Flofocus - 03-13-2007
[right][snapback]230182[/snapback][/right]
it is a pita to replace but it can be done. If I can do it, a more experienced DIY's can def do it. Do the timing belt while your at it. ;)
Water Pump #@$%^^&& - 02ztsian - 03-13-2007
I had a rattle in the front as well. I thought it was valve train related but apparently when I swapped back to stock pulleys I had a water pump bolt come loose and it fell off. I have lost two so far so I finally splurged for some thread locker. Just a thought but check to see if the three bolts are loose at all, esp. if you have ever had the pulley off for any reason.
Water Pump #@$%^^&& - mo_focus - 03-13-2007
Are you sure its the water pump and not the t-stat housing? Usually on our cars the t-stat housing goes before anything else
[right][snapback]230187[/snapback][/right]
That's what I'm thinking. I was planning to do the belt this year, but, the pump wasn't on my list.
[right][snapback]230192[/snapback][/right]
It's not leaking yet. Just a rattle.
02ztsian,Mar 13 2007, 09:22 AM Wrote:I had a rattle in the front as well. I thought it was valve train related but apparently when I swapped back to stock pulleys I had a water pump bolt come loose and it fell off. I have lost two so far so I finally splurged for some thread locker. Just a thought but check to see if the three bolts are loose at all, esp. if you have ever had the pulley off for any reason.
[right][snapback]230190[/snapback][/right]
I bought it from a used car dealer. He told me that he had to replace the tensioner wheel, or the idler wheel, but that was 60,000 kms ago, last April.
Water Pump #@$%^^&& - oldeguy - 03-19-2007
My buddy the mechanic had a listen to my engine. He said everything is good. He did say that when I do the Timing Belt, I might as well do the pump and serpentine belt too. Crisis avoided. I need my car to get to work, and work can be a 7 day a week thing. Now, I know what I'm doing the first day of "vacation"
