Leaking - Printable Version
+--- Thread: Leaking (/showthread.php?tid=6407)
Leaking - oldeguy - 03-12-2007
Anybody fixed this one? 2.0 L Zetec. How much for the Valve Cover Gasket?
Leaking - hardk0re - 03-12-2007
Oil leaking down the front of the engine? The valve cover gasket is $21 USD which somehow translates to $58CDN when you buy it from a canadian ford dealer...
Easy fix, hardest part is earning the cash to pay for the damn piece of rubber...
hardk0re,Mar 12 2007, 07:10 AM Wrote:Oil leaking down the front of the engine?  The valve cover gasket is $21 USD which somehow translates to $58CDN when you buy it from a canadian ford dealer...
[right][snapback]229876[/snapback][/right]
Oil leaking down the front, I can see where it is coming from. Front, right hand side. Do you know if anyone other than Ford sells the part?
Leaking - habmann - 03-12-2007
I just did mine a couple of months ago. For sure the worst part of the job is forking over the money for the gasket.
The actual gasket replacement is really just a straight forward swap, anyone can do it.
Leaking - Flofocus - 03-12-2007
make sur eyou follwo the recommended torque specifications. Some people tighten it down to much and that is what is causing their leaks.
Leaking - NikiterZTS - 03-13-2007
a How To
Click
not sure whats up with pics
