Putting Tom Motorsports Seats In The Foci - Printable Version
+--- Thread: Putting Tom Motorsports Seats In The Foci (/showthread.php?tid=6444)
Putting Tom Motorsports Seats In The Foci - smith21 - 03-09-2007
as it says..i'm looking to put my new set of tom motorsports seats in my car...just curious, what brackets do i need to pick up? if any, and am i gonna have to be creative and fab myself up something?
Putting Tom Motorsports Seats In The Foci - focusonthis_88 - 03-09-2007
smith21,Mar 9 2007, 12:25 AM Wrote:as it says..i'm looking to put my new set of tom motorsports seats in my car...just curious, what brackets do i need to pick up? if any, and am i gonna have to be creative and fab myself up something?
[right][snapback]229447[/snapback][/right]
It would probably be way cheaper to get someone to make you the brackets.
Putting Tom Motorsports Seats In The Foci - hardk0re - 03-09-2007
I think the best way is to use the Corbeau brackets that don't come with sliders, get the models with the T at the end I think its 2008T and 2009T. T stands for tall, and these brackets come with sliders.
They aren't a direct bolt up, another member on this site used 1/4" Steel and made a bracket. Basically just mounted the blate to the seat bracket then the seat to that plate.
I used 1/4" high grade aluminum, slightly more but it weighed allot less than the steel.
Putting Tom Motorsports Seats In The Foci - Focus man. Focus. - 03-09-2007
When I installed my MOMO seats I used the MOMO sliders and mounted them on Sparco bases. All the bolt holes lined up perfectly and the fit was excelent. The only thing I needed to do was put about 4 washers under the front mounting bolts to angle the seats back a little. The MOMO seats I had were a fixed back with no adjustment so I had to shim them to get them the way I wanted. Hope this help with your install and lets see some pic's when your done.
Putting Tom Motorsports Seats In The Foci - Black_ZTS - 03-10-2007
I use Recaro seat base for my Recaro replica which uses the same slider as the Tom's. I need to drill two holes at the base since the crappy sliders is shorter then the real recaro's.
Putting Tom Motorsports Seats In The Foci - smith21 - 03-10-2007
yea, i have the sliders that came with the seats..gonna do some more homework after ur help
