What Is The Better Setup - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Regional (//www.focuscanada.net/forum/forumdisplay.php?fid=7) +--- Forum: Québec (//www.focuscanada.net/forum/forumdisplay.php?fid=38) +--- Thread: What Is The Better Setup (/showthread.php?tid=6490) |
What Is The Better Setup - fastfocusgigi - 03-05-2007 i have a 2007 zx3 gfx and there's not dat much suspension kits to choose from. i have 2 choises. 1 - Tokicoââ¬â¢s hp serier shock and strut + eibach pro kit springs 1.6 drop (more expensive and more difficult to find in montreal) 2 ââ¬â ford racing shock and strut kit + ford racing spring kit 1.6 drop (seems cheaper and lower quality) what is the best setup. thanks pardonné moi pour mon anglais..... :rolleyes: What Is The Better Setup - ZED_not_zee - 03-05-2007 Honestly the ford racing kit will probly be better becasue the shock/struts are matched to the springs to work together.... What Is The Better Setup - NOS2Go4Me - 03-05-2007 I'm pretty sure Eibach makes a 2006+ suspension kit, if not two. Check with Mitch or check the Eibach website. What Is The Better Setup - fastfocusgigi - 03-06-2007 NOS2Go4Me,Mar 4 2007, 01:15 PM Wrote:I'm pretty sure Eibach makes a 2006+ suspension kit, if not two. Check with Mitch or check the Eibach website. eibach only have springs kits for 2006+'s if you can find a kit please let me know because i want it now :angry: i whant the care to look nice this summer B) how can i get in contact whit Mitch What Is The Better Setup - Ghandi - 03-13-2007 As far as I know the 2000-2004 and 2005+ focus all share the same suspension setup since it's the same chassis. The only differnece are for wagons which have different rear shocks. All the suspensions available for the focus since day 1 should fit bolt-on. En gros vérifie comme il faut car je metterais ma main au feu que TOUT les ensembles d'amortisseurs ET de ressorts pour la focus sont compatibles du fait quele chassis est le même. En gros tu as beaucoup plus de choix que tu le crois. What Is The Better Setup - fastfocusgigi - 03-14-2007 Ghandi,Mar 12 2007, 08:42 AM Wrote:As far as I know the 2000-2004 and 2005+ focus all share the same suspension setup since it's the same chassis. non, je suis sur que le setup du modele 2006 et 2007 ne sont pas les même que les autres années. ford àdécidé de changer les ''knucles'' sur les nouveaux modèles, dons la base des shocks n'est plus la même. What Is The Better Setup - ZED_not_zee - 03-14-2007 yea he's right the knucles area new design... mazda three parts might swap in did you try that angle? What Is The Better Setup - Ghandi - 03-15-2007 The new redesigned knuckle is from the focus SVT, which uses all the same suspension components of every 2000/2004 focus. All brake and suspension parts are interchangeable regardless of the year. What Is The Better Setup - fastfocusgigi - 03-15-2007 Ghandi i sure hope your wrong, because i have a ford racing svt suspension kit. i installed it on my 2003 focus and removed it when i brought it back now i ordered a tokico suspension kit for my new 2007 focus because everyone else tells me that it doesn't fit. What Is The Better Setup - ZED_not_zee - 03-15-2007 Ghandi,Mar 14 2007, 11:07 AM Wrote:The new redesigned knuckle is from the focus SVT, which uses all the same suspension components of every 2000/2004 focus. so your saying I can put 07 knuckles in my 00? I hope your right... What Is The Better Setup - Ghandi - 03-16-2007 As far as brake upgrade goes, here's what I found a few weeks back in the 2007 Ford Racing catalog. ![]() A brand spankin new setup which clears the 15'' stock wheels. And the new redesigned 2005+ front knuckle is included. I can't say for sure on this one but it looks hella close to the brake setup of a common ST focus found in North America. Also you have the full SVT focus brake ungrade available with 300mm front rotor but the min. wheel size is 16 inches. What Is The Better Setup - Ghandi - 03-17-2007 Allright, just to make sure I didn't mislead anyone. I found infos regarding the ''new'' suspension setup used in 2006+ focus. Focaljet link From 2000 to 2005 included, everything is identical. 2006+ got a few differences and they're NOT backward compatible. In any case I want to excuse myself for any misinformations I may have said. I stand corrected. |
