Headlight/foglight Issues - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Headlight/foglight Issues (/showthread.php?tid=6656) |
Headlight/foglight Issues - residentdud - 02-15-2007 Hey Guys and Gals, I'm having a problem with my lights. When I turn them both on (headlight and foglights) only one side works. I checked the fuses and everything looks good. Could it be a relay? It's not very people friendly outside so all I've done was check the fuses. Any ideas? Thanks. Darryl Headlight/foglight Issues - mpcv2000 - 02-15-2007 Stupid question but did you check the bulb ? Take 2 second to remove.. Headlight/foglight Issues - residentdud - 02-15-2007 mpcv2000,Feb 14 2007, 11:47 PM Wrote:Stupid question but did you check the bulb ? Yeah, lamps are good...It's just kinda weird that my headlight and fog light are out on the right side. Headlight/foglight Issues - Frost__2001 - 02-15-2007 it sounds like it might be a relay or it could be the switch itself Headlight/foglight Issues - residentdud - 02-16-2007 Frost__2001,Feb 15 2007, 12:57 PM Wrote:it sounds like it might be a relay or it could be the switch itself I hope so. Any ideas guy's before I go to the dealer? It's only the passenger side fog and passenger side headlight. Thanks. Headlight/foglight Issues - NoiSeeVT - 02-16-2007 I just had the same problem and it was a melted switch, mine was the left side. Ford fixed mine under warrenty. David |
