Door Lock Problem - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Door Lock Problem (/showthread.php?tid=6749) |
Door Lock Problem - hyprlte - 02-05-2007 so i went to lock my doors of my 2000 zx3 with the remote and it sounded like the door tried to lock three times (i heard the lock noise 3 times). When that happens sometimes it locks and sometimes it does not. Has anybody had this problem before? Door Lock Problem - Mason - 02-05-2007 did it eventually lock or did you have to do it manually. How cold is it where you are. Could just be frozen Door Lock Problem - hyprlte - 02-05-2007 it eventually locks, i actually cant open the door manually, only through the remote, and i was having this problem before it got really cold...could it be that the power lock is dying? Door Lock Problem - Mason - 02-05-2007 hyprlte,Feb 4 2007, 09:03 PM Wrote:it eventually locks, i actually cant open the door manually, only through the remote, and i was having this problem before it got really cold...could it be that the power lock is dying? Ya. its probibly the actuator. pull the door skin off one day and make sure everything is still connected and nothing is seized on the inside. Door Lock Problem - SmokeBCBuDZ - 02-05-2007 I have a similar problem where the actuator will partially unlock my passenger door and then I have to manually open the door from the inside. Heres a link that may help you. door latch fix Door Lock Problem - Frost__2001 - 02-05-2007 the other problem could be the battery in your remote, if you have the spare one kicking about, that you don't usually use, try it and see if that works. Door Lock Problem - hyprlte - 02-05-2007 SmokeBCBuDZ,Feb 5 2007, 01:21 AM Wrote:I have a similar problem where the actuator will partially unlock my passenger door and then I have to manually open the door from the inside. Heres a link that may help you. the door opens fine, it just sometimes wont lock. i tried using the spare remote but nothing... i think it might actually be the power lock Door Lock Problem - smith21 - 02-05-2007 my car's been doing the same thing actually hyprlte...haven't brought it in or anything to see what's up with it..so when you find out, lemme know Door Lock Problem - hyprlte - 02-05-2007 smith21,Feb 5 2007, 03:03 AM Wrote:my car's been doing the same thing actually hyprlte...haven't brought it in or anything to see what's up with it..so when you find out, lemme know i will fusure. I think it might be going in next week. I will keep you posted Door Lock Problem - Mason - 02-05-2007 hyprlte,Feb 5 2007, 02:02 AM Wrote:smith21,Feb 5 2007, 03:03 AM Wrote:my car's been doing the same thing actually hyprlte...haven't brought it in or anything to see what's up with it..so when you find out, lemme know The quick fix solution if its frozen is to thaw it out with de icer or somthing then spray some graphite in there. Door Lock Problem - hyprlte - 02-07-2007 i know its definately not frozen |
