Lights Dimming Still - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on I.C.E. (//www.focuscanada.net/forum/forumdisplay.php?fid=23) +--- Thread: Lights Dimming Still (/showthread.php?tid=6827) |
Lights Dimming Still - Chromey - 01-26-2007 I did the Big 3 And My Lights still dim big time when Bass hits. What i Have: Yellow top Batt 4gauge from Alt to Batt 4Gauge from Engine to Chassie 4gauge from engine to Batt System: Ultimate T3 500D Mach 5 Audio 12" In a 4th order Bandpass I running 8gauge to the amp(Power) 6gauge grounded to the chassie. Would a 1.5f Cap help Cause i have 1. Any help would be great. Lights Dimming Still - tippmann - 01-26-2007 im pretty sure if you put the cap on it will help with the dimming Lights Dimming Still - mpcv2000 - 01-26-2007 I'd say it's normal , try with 2 battery ( like if you were boosting the car ) and it should not do it. You're peaking your electric system . ( I'm guessing tho... ) My lights are dimming too in my car but they are more like "flikering" , I have no amps so it's not that , I know the Focus are known for that but it has nothing to do with your issue. :P Lights Dimming Still - mpcv2000 - 01-26-2007 Chromey,Jan 25 2007, 08:41 PM Wrote:Would a 1.5f Cap help Cause i have 1. Is it installed ? Lights Dimming Still - Chromey - 01-26-2007 I should also Add I have UDPs.... Cap is Not installed yet Lights Dimming Still - MAlby7 - 01-26-2007 Sent you a PM back. Lights Dimming Still - Drivesthebeast - 01-29-2007 If you are using a stock alternator and UDP's...you just answered your own question/problem my friend. |
