Need Help With Iat / Spark Plugs. - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Need Help With Iat / Spark Plugs. (/showthread.php?tid=7181) |
Need Help With Iat / Spark Plugs. - kamilk69 - 12-15-2006 well since ive put my turbo in have had the check engine light on, the error is for a high air intake temp reading. now im using a 2001 mustang MAF, and they had extrenal IAT, so how do you wire in the stock focus one to make it work, or do i have to get a mustang IAT, and rewire it. any help would be appreciated. and one more thing, any one have the part number for a NGK spark plugs that are one step colder, or some brand that i can pick up in Canadian tire. Need Help With Iat / Spark Plugs. - Flofocus - 12-16-2006 1 step colder... Motorcraft azfs22c, mine are gapped to .040. Theyre dirt cheap form ford, think theyre like $3-4 each. IAT, no clue...pro-m integrates it in the hosuing im pretty sure... Need Help With Iat / Spark Plugs. - hardk0re - 12-16-2006 The IAT in the FOCUS is PIN 1 and PIN 6, you'll notice that these two pins don't plug into the Mustang MAF. If you did things the cheap way on your kit you possibly bought a BOMZ intake for the intake tube. This would be great, you can then just drop your stock MAF into this hole and wire up pin 1 and pin 6. Then your IAT will be fine. Else you will need to buy a mustang IAT and wire it up. It does matter how you wire it up I can look, but the easiest would be using the stock MAF. Need Help With Iat / Spark Plugs. - kamilk69 - 12-17-2006 could you look up how to wire a mustang iat up, i found a mustang iat for 15$. Need Help With Iat / Spark Plugs. - hardk0re - 12-17-2006 Just pull or splice the two wires from the stock MAF Labeled 1 and 6. Connect these two wires to the new mustang MAF. It doesn't matter which way you wire them up. Need Help With Iat / Spark Plugs. - mpcv2000 - 12-17-2006 kamilk69,Dec 15 2006, 01:53 AM Wrote:Any help would be appreciated. Read this article this should answer some of your questions. Clic here ... Need Help With Iat / Spark Plugs. - darkpuppet - 12-19-2006 I had used a lightning IAT in the form of a relocation kit form CFM.. Need Help With Iat / Spark Plugs. - SliverSteeda - 12-19-2006 hardk0re,Dec 15 2006, 01:23 PM Wrote:The IAT in the FOCUS is PIN 1 and PIN 6, you'll notice that these two pins don't plug into the Mustang MAF. Did you just say buying something from Bomz is great? that might be a first.... Need Help With Iat / Spark Plugs. - Flofocus - 12-19-2006 yes, buying a bombz intake pipe is great for charge piping on a diy turbo job. |
