Focus Tsbs - Printable Version
+--- Thread: Focus Tsbs (/showthread.php?tid=7458)
Focus Tsbs - ZTWsquared - 11-20-2006
SSM 19468, OASIS Service Codes: 304000, 702000, 702200, 702300, 703200, 703300, 703400
2006-2007 Focus - Rear Shock Chuckle Noise over Bumps (Sedans & Coupes only)
Some 2006-2007 Focus Sedan & Coupe vehicles may exhibit a chuckle/rattle noise from the rear shock area when driven over bumps at low to moderate vehicle speeds. Check trunk/hatch/storage area for loose items and secure. Check suspension for loose or leaking components and repair as necessary. If root cause can not be determined and isolation leads to the rear shock or upper shock mount, do not replace these components. Engineering is currently investigating the concern. Monitor OASIS for updates.
TSB 06-23-1, OASIS Service Codes: 505000, 505200, 506000, 510000
2006-2007 Focus - Transmission Fluid Leaks From Bell Housing or Inability to Shift into Gear Due To Clutch Slave Cylinder Leak
Some 2006-2007 Focus vehicles produced after 12/4/2005 and equipped with a manual transmission may exhibit a slave cylinder leak which may lead to the inability of the customer to shift the transmission into gear. Follow the TSB Service Procedure steps to correct the condition by replacing clutch disc, pressure plate and clutch slave cylinder. REFER TO THE TSB FOR COMPLETE SERVICE REPAIR AND PART INFORMATION.
Focus Tsbs - ZX5chica - 11-20-2006
A big thank you on both of those OASIS updates... two problems I was planning on bringing into the dealership within the next little bit
