Engine Check Light - Printable Version
+--- Thread: Engine Check Light (/showthread.php?tid=7524)
Engine Check Light - NikiterZTS - 11-13-2006
so i installed my header yestarday, put the cheater on and everything.....so thing worked fine.....30 mins ago i came out out of the movies, started driving and all of the sudden my engine check light came on, so im like wtf
i will also mention that the cheater i got was home made, so im not sure with what quality its made with .......or could it be one of my 02 sensors?
i wouldn't mind run Xcal on my car or some sort of check to see what the codes are like....
any ideas?
thanks
Engine Check Light - Chromey - 11-13-2006
Get a Chip or Xcal, Problem solved.
Ive seen people with Boughten Mil-el ,Still get a Code.
Get a tune call it done.
Engine Check Light - 02ztsian - 11-14-2006
Which sensor did you connect it to? It should go in the one closest to the rad (see picture); the one on the 2-3 collector.
[Image: Im005782.jpg]
You should be able to just make out which one I mean.
Engine Check Light - NikiterZTS - 11-14-2006
ok yea, i did put it in the other one.....will change it when i get home.
thank you Ian
Don't forget to disconnect the battery to clear the ECU.
so my bad it was in a 2-3 collector......so i unplugged the battery, unpluged and reconnected the cheater....started it there was not engine check,,,,so im gonna go out for a bit tonight later on and see if its gonna come back on
