E-brake Cables - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: E-brake Cables (/showthread.php?tid=7783) |
E-brake Cables - habmann - 10-20-2006 Ok guys I need some help. When i set my e-brake it works properly, but when i release it, the handle feels like the cable hasn't released. I've been told that the rear cables need to be changed, does anyone know how much work it is to change them? Anyone done this themselves? Or does anyone have any idea what else it might be? I've tried adjusting the screw on the end of the e-brake handle and that doesn't help. Thanks guys. E-brake Cables - habmann - 10-21-2006 Bump. No one has any ideas? E-brake Cables - Chromey - 10-22-2006 Just a Shot But Get under the Car And Make WD-40 Proud. E-brake Cables - habmann - 10-22-2006 Chromey,Oct 21 2006, 11:14 PM Wrote:Just a Shot But Get under the Car And Make WD-40 Proud. My mechanic tried that when he did the rear drums in the spring. Helped for a lil while, but didn't really solve the prob. I think the cables are streched so i'm more concerned about anything i might need to know ahead of time before i change them. E-brake Cables - kc focus - 10-23-2006 It sounds like you may need cables but I would have to see it to tell you for sure....I live in Hamilton as well and do some work on the side at home....I'm a mechanic.. E-brake Cables - reldridge - 10-23-2006 WD-40 will dry out after awhile. Try using a good lubricant like the Krown stuff (KL73 I think). You can get it at Home Hardware. WD-40 is great, but it's not a long term lube, more of a penetrant. If it worked for awhile, then stopped, probably it dried out. Ryan E-brake Cables - bigman - 10-26-2006 Ebrake cables arent that much money and there easy to do. hardest thing i found with mine was the heat shield. id just replace them and get it done with. E-brake Cables - habmann - 10-26-2006 Being that i just don't seem to have the time these days, its going to the mechanics on friday to have them changed. E-brake Cables - vy_MR2 - 10-27-2006 the nice thing with the focus is that it not only has the cable from the ebrake back, but has 2 short cables, maybe 18 inches long, one to each wheel. As for pricing, I think whe i changed mine, it cost 15 a piece. E-brake Cables - habmann - 10-28-2006 Well got the car back today, needless to say i wish i had had the time to do it myself. Woulda been far cheaper. Oh well the cost to have time to do other things i guess. |
