Help - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Regional (//www.focuscanada.net/forum/forumdisplay.php?fid=7) +--- Forum: Québec (//www.focuscanada.net/forum/forumdisplay.php?fid=38) +--- Thread: Help (/showthread.php?tid=7919) |
Help - fastfocusgigi - 10-09-2006 je vais faire ca vite. moteur tremble énnormément sur idle pas de puissance du tout de la misère àrouler à100km/h le pied au fond ca sent les oeuf pourrit pas de check engine Help - NikiterZTS - 10-09-2006 fixed up Help - Oscar The Grouch - 10-10-2006 NikiterZTS,Oct 9 2006, 03:37 AM Wrote:whatever you say dude :) alors. Il parle francais idiot. Sur la question, regard ta filter d'essence et la pompe. La pompe c'est probablement mort. Help - ZX5chica - 10-10-2006 fastfocusgigi,Oct 8 2006, 09:38 PM Wrote:je vais faire ca vite. Translation... The car is idling rough, there is no power, and he's having a hard time getting it up to 100km/h. There is no check engine light that comes on, but it smells like rotten eggs when the car is running... Help - fastfocusgigi - 10-10-2006 its the wire connected to the coil .........the one on the right how can i repair thank you for the translation. Help - NikiterZTS - 10-10-2006 Oscar The Grouch,Oct 9 2006, 09:26 AM Wrote:NikiterZTS,Oct 9 2006, 03:37 AM Wrote:whatever you say dudeà:) fixed comment Help - mo_focus - 10-10-2006 Oscar The Grouch,Oct 9 2006, 02:26 PM Wrote:NikiterZTS,Oct 9 2006, 03:37 AM Wrote:whatever you say dudeà:) I'll say plugged catalytic converter. if you try everything else and it doesnt work, go for emition testing and it should tell you if you catalytic is gone or not. Here is in french(dont laugh at me its google translator) Je dirai le convertisseur catalytique branché. si vous essayez tout autrement et lui travail de doesnt, aller pour l'emition examinant et il devrait t'indiquer si vous catalytique est allé ou pas. Help - ZX5chica - 10-10-2006 fastfocusgigi,Oct 9 2006, 02:14 PM Wrote:its the wire connected to the coil .........the one on the right Pas de problème. Si vous avez jamais besoins d'aide, il y en a des uns ici qui parlent français, ou qui viennent de la région d'Ottawa/Outaouais. J'espère que votre problème sera réglé le plus tôt que possible. :) Help - djrard - 10-11-2006 ya des brosse chances que ton catalyseur soient du pour etre changer. Sinon p-e la timing belt a sauté une coche ou p-e bien que le coil fait défaut. Mais je miserais plus sur un catalyseur bouché Help - BerinG - 10-11-2006 moi je vérifierais le filtre àgaz ou la pompe àgaz.. jai du faire changer la mienne 2 ans passé pour le meme problème.. SAUF que ce ne semblait pas majeur comme toi.. As-tu un cold air intake? pourrais til y avoir quelque chose de coincé dans le tuyau? peut tu monter jusqua 6000rpm ou si il reste pris à3000-4000 même avec la pedal au fond? Regarde la ligne qui est brancher a larriere du intake manifold.. il devrais y en avoir 4 ensemble et une plus grosse en dessous des autres.. ca connecte àta ligne PCV (qui ce rend àl'avant du moteur).. ca ce pourrais que la hose soit fendu .. Help - mpcv2000 - 10-16-2006 djrard,Oct 10 2006, 12:30 PM Wrote:Mais je miserais plus sur un catalyseur bouché I'll second that , cloged up catalitic converter. Cataliseur boucher. It did happen to me on a Dodge van , symptomes were the same as you described. Help - Taliesin - 10-18-2006 Quote:I'll say plugged catalytic converter. if you try everything else and it doesnt work, go for emition testing and it should tell you if you catalytic is gone or not. I'm not sure we HAVE emission testing here in Quebec... maybe at the dealership. Or maybe at the SAAQ's 'mandataires...' :ph34r: Help - ZTWsquared - 10-18-2006 NikiterZTS,Oct 9 2006, 04:03 PM Wrote:ti che pidaras vashe uje ohuelThis is the Quebec forum dude so get with the program - comments like "whatever" in reference to a post in French is close to insulting - and your comments in Russian (?) better not be. Help - NikiterZTS - 10-18-2006 ZTWsquared,Oct 18 2006, 08:04 AM Wrote:NikiterZTS,Oct 9 2006, 04:03 PM Wrote:ti che pidaras vashe uje ohuelThis is the Quebec forum dude so get with the program - comments like "whatever" in reference to a post in French is close to insulting - and your comments in Russian (?) better not be. fixed comment |
