Sticky Gas Pedal - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Sticky Gas Pedal (/showthread.php?tid=8005) |
Sticky Gas Pedal - biggorilla - 09-30-2006 Have a 2005 Focus ZX-5 SES... Does anyone else have a problem with the gas pedal catching at the top? Initially it only happened when it's cold (outside temp), but recently seems to happen at random... which can be a real drag with a 5-speed, let me tell you... Anyhow... if anyone has any comments... bring 'em on... Biggorilla Sticky Gas Pedal - ANTHONYD - 09-30-2006 Common problem. If you're still under warranty, take it in. If not, just add some lube on the spring mechanisim. Sticky Gas Pedal - snorcus - 09-30-2006 We just had one in here the other day under waranty and it neede the TB . Lubing the srpring is good if you have to pay but if the dealer says they are only going to do the lube you should make a fuss cause it will just start happening again down the road, and it is a striaght forward waranty claim for the dealer. Sticky Gas Pedal - schade - 09-30-2006 someone that has a car under warrenty still wanna put my TB on there car and get a new one please :D Sticky Gas Pedal - Drivesthebeast - 10-01-2006 I have the same problem with my FC TB...I need to lubricate the spring mech, as well as the throttle cable, and sometimes take the DPFE sensor off the car and clean and dry it out, as moisture often renders it inoperable... Sticky Gas Pedal - kc focus - 10-07-2006 You may have some carbon build up around the trottle plate..... |
