Outside Focus Keypad - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Outside Focus Keypad (/showthread.php?tid=8375) Pages:
Outside Focus Keypad - Acid0057 - 08-29-2006 Hey Guy I got a 2000 Ford Focus and the keypad on the drivers side doesn't work. Any ideas? Outside Focus Keypad - euro_zx5 - 08-29-2006 I believe it's an RF based transmitter, so it could just need a battery replacement. Outside Focus Keypad - Acid0057 - 08-29-2006 Nope its the outside keypad like this one: Ford Accessories Web Link to Keyless Entry Keypad Also the lights light up on it at night when I press it. Do I need to add it to my cars security database? And whats the default code for them? Outside Focus Keypad - mo_focus - 08-29-2006 didnt know our cars came with it. I have never seen it on a focus before Outside Focus Keypad - euro_zx5 - 08-29-2006 Yeah, that's the one I meant. I've never actually seen one, but i'm assuming you can pop the cover off and change the battery... Acid0057,Aug 28 2006, 08:45 PM Wrote:Nope its the outside keypad like this one: Outside Focus Keypad - ANTHONYD - 08-29-2006 In all my years close to this car.... I'VE NEVER SEEN ONE OF THOSE ON A FOCUS. :blink: Outside Focus Keypad - jen_deans - 08-29-2006 I like it! :) Outside Focus Keypad - Frost__2001 - 08-29-2006 yeah I've seen those on Foci before, it's a dealer installed aftermarket install. but if anything it could be a few things, one water got into it and shorted it out, battery in it died, cables could have corroded, or if they didn't seal the hold on the door right it might have cut the wires. Outside Focus Keypad - S2 - 08-30-2006 ANTHONYD,Aug 29 2006, 06:48 AM Wrote:In all my years close to this car.... I have actually seen this before, as mentioned in the previous post, it's a dealer installed option out of the FORD ACCESSORY brochures. Outside Focus Keypad - Acid0057 - 08-30-2006 Ok a couple of things. First off I don't think its the batteries. The pad lights up green at night. And if I did need to change it how would I pop the cover off? Second I don't think its wired, is it? Do I need to add it to my security system, much the same way that I would add a new fob or key to the security system? Outside Focus Keypad - euro_zx5 - 08-30-2006 Well that's how they are programmed in the first place, yes. Did you do anything that would require the remotes to be reset? I don't think disconnecting the battery would even cut the codes/pairing of keypads in the first place... so I don't know what would cause this problem. If it's obviously got power, there shouldn't be any reason for it to not function correctly. Honestly, best bet would be to go to the dealer if the well known Focus-forums can't be of any help, cause rarely do we see these installed on any Foci. Outside Focus Keypad - NefCanuck - 08-30-2006 Yeah, another vote for go back to the dealer here... But I really like the idea of that pad, no more fishing around in my pockets for the Key Fob O' Doom Wonder how much it costs all in to add it? :huh: NefCanuck Outside Focus Keypad - deadSkip - 08-30-2006 NefCanuck,Aug 29 2006, 07:03 PM Wrote:Yeah, another vote for go back to the dealer here... Something like just under $300 and that's not including the labour and install charges... saw the little display they had at Colony Ford a few times in their parts dept. area on the counter with frost a few times when we went there. Outside Focus Keypad - NefCanuck - 08-30-2006 deadSkip,Aug 29 2006, 07:39 PM Wrote:NefCanuck,Aug 29 2006, 07:03 PM Wrote:Yeah, another vote for go back to the dealer here... $300 + labour/install charges? Yipes that's gonna be $700 all in I'm guessing... Maybe I should do the smarter thing and get hood props installed with that $, save myself from nearly being guillotined every time I open the #$%$'ing hood <_< NefCanuck Outside Focus Keypad - Acid0057 - 08-30-2006 Well I got the car used and it wasn't working. Then I had a few keys cut and logged into the CLM. I suppose it would have been taken out of the mix then. But since I got the car used I don't know the default code to activate the pad when adding it to the CLM. Is there a general default code for these things? Also the dealership wasn't much help. Outside Focus Keypad - meford4u - 08-30-2006 Acid0057,Aug 29 2006, 08:33 PM Wrote:Well I got the car used and it wasn't working. Then I had a few keys cut and logged into the CLM. I suppose it would have been taken out of the mix then. But since I got the car used I don't know the default code to activate the pad when adding it to the CLM. Is there a general default code for these things? Also the dealership wasn't much help.Try checking in the trunk and see if it is located on either of the supports. That's where we used to put the sticker from the factory. Outside Focus Keypad - Acid0057 - 08-30-2006 Near the wheel wells in the trunk? Also what do I do once I find the code? Outside Focus Keypad - meford4u - 08-30-2006 Acid0057,Aug 29 2006, 10:03 PM Wrote:Near the wheel wells in the trunk? Also what do I do once I find the code? It should be on the trunk supports. I assume you have also checked the glove box for the code. If that doesn't work go to a dealer as they have a code to reset the keypad and give you a new number. Outside Focus Keypad - OAC_Sparky - 08-30-2006 The Focus keypad (which works with other Fords as well) works basically the same way as your key fob does, and has to be programmed. It's possible that the module has lost the fob code (dead battery), or you are not entering the correct code. There are no wires, it's just stuck on the door, it has batteries inside. Quote:Conveniently unlock your vehicle without your key or keyless entry remote. No wiring necessary ââ¬â programmable, backlit keypad tunes to the same frequency as your transmitter. Long-life battery (lasts 100,000 cycles). Easy no-drill installation. For vehicles equipped with factory remote keyless entry. I'll try to remember to check when I'm at work to download the programming instructions. Outside Focus Keypad - ANTHONYD - 08-30-2006 Sounds like it needs to be reset. Maybe some tard who knows how to re-program the device did it when you weren't around :blink: :dunno: |
