On The Way To Work...... - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: On The Way To Work...... (/showthread.php?tid=866) |
On The Way To Work...... - oldeguy - 09-23-2009 On the way to work, the car started sounding REALLY ODD. I turned around, got it back home, lifted the hood, to find the number three spark plug, still in it's boot sitting on top of the valve cover. I have sent it out to the Doctor, to see what the heck happened, and what it'll cost to repair, either a new engine or just a repair. If it's too much, I will be looking for another Focus On The Way To Work...... - ZX3_2NV - 09-23-2009 Did you try sticking it back in? It was only running on 3 cyl how long were youd driving like that? When you first heard it weird you should of taken a look under the hood. On The Way To Work...... - Oscar The Grouch - 09-23-2009 Don't you have an extended warranty till 2014 or something like that? On The Way To Work...... - Focus man. Focus. - 09-24-2009 How much boost are you running in that thing? LOL Were the threads visible on the plug or were they covered in aluminum? It may be as easy as getting a spark plug thread repair kit and fixing the hole. On The Way To Work...... - oldeguy - 09-24-2009 Focus man, Focus.,Sep 23 2009, 10:41 AM Wrote:How much boost are you running in that thing? LOLthreads were visible, no aluminum. On The Way To Work...... - Scorcher000 - 09-24-2009 Wow, i was told once that never tighten the spark plugs on the duratec too tight because there isn't enough head to hold it if you crank it. I asume thats for most cars but this sitch is weird. Witch craft to be more like it. Is your house on old native reserve by any chance. :o On The Way To Work...... - ZTWsquared - 09-24-2009 Scorcher000,Sep 23 2009, 01:50 PM Wrote:Wow, i was told once that never tighten the spark plugs on the duratec too tight because there isn't enough head to hold it if you crank it. I asume thats for most cars but this sitch is weird. Witch craft to be more like it. Is your house on old native reserve by any chance. :o Call me anal but I always clock my spark plugs and use a torque wrench to tighten ... the spec on Duratec20 is 12 nm or 9 lbs-ft and I'd be surprised if the spec on Zetec was much different. On The Way To Work...... - oldeguy - 09-24-2009 Good news and bad news...............car has been repaired. one helio? coil, one spark plug , one hour of labour. $85.00 Saw a couple of Focus's on Autotrader for around $4000.00 On The Way To Work...... - Focus man. Focus. - 09-24-2009 Helicoil. Threaded insert to repair stripped threads in spark plugs, cylinder heads or just about anything you can f'up. On The Way To Work...... - darkpuppet - 09-24-2009 glad it's repaired... on the subject of torque specs, I've found Ford torque specs to be rather high compared to other car companies... anyone else ever notice that? my GF's nissan's torque specs would almost qualify as 'finger tight'. On The Way To Work...... - Scorcher000 - 09-24-2009 darkpuppet,Sep 23 2009, 04:03 PM Wrote:glad it's repaired... For the wheel nuts, yes. Fords are one of the highest to be torqued compared to the others lol. except a Enzo which is like almost 700 or 900 ftq, signle bolt |
