Focus Rack Problems - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Focus Rack Problems (/showthread.php?tid=918) |
Focus Rack Problems - Jmountney1 - 09-11-2009 soo Finally we installed the new tranny and clutch in my fofo butttttttt the power steering pressure hose from the power steering pump to the rack/steering gear was rotten and broke so a day later and $80 we attempt to install the hose but that requires us to remove the steel line from the spool valve to the power piston on the rack. of course its also rotten and brakes. butt here is the good part ford clams you cannot buy that steel line new any more. has any one had to replace this line. should we try and fab one up or try a wrecking yard. any help would be appreciated :) ps: at least the MBRP bolted up with no issues. thanks nikiterZTS |
