Loss Of Some Coolant From Recovery Tank - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Loss Of Some Coolant From Recovery Tank (/showthread.php?tid=9279) |
Loss Of Some Coolant From Recovery Tank - NefCanuck - 06-15-2006 Okay, I'm probably worrying over nothing at this point but wanted to know if anyone else had experienced this. From the time I bought the car last April the coolant level in the recovery tank was always just below the MAX line. Tonight when I parked it at the Mapleview Cruise Night I noticed the level had dropped halfway between the MAX & MIN lines on the tank. I have less than 36K on the odometre, I'm obviously gonna keep an eye on things but is a small loss of coolant from the recovery tank normal over time or should I bring it in to Ford sooner than the regularly scheduled 40K raping in July? NefCanuck Loss Of Some Coolant From Recovery Tank - hardk0re - 06-15-2006 Check it after a while, it will probably go back up where its supposed to be. Loss Of Some Coolant From Recovery Tank - Phantom - 06-15-2006 Or quite possibly since there is still some water in the mix. Evaporation :D Loss Of Some Coolant From Recovery Tank - NOS2Go4Me - 06-15-2006 I'd be more worried about the temperature gauge than the coolant alone, especially if it's above the minimum line. Is it pure evaporation? Are you noticing any puddling of coolant on the ground at all? A sweet smell while driving? Loss Of Some Coolant From Recovery Tank - NefCanuck - 06-16-2006 NOS2Go4Me,Jun 15 2006, 08:12 AM Wrote:I'd be more worried about the temperature gauge than the coolant alone, especially if it's above the minimum line. Actually I distrust the temp guage on the Focus mainly because its a pure idiot light disgused as a guage. It only moves away from normal after things have gone to hell in a handcart and by then the damage is done <_< No puddlling visable under the car and I haven't noticed any sweet smell at all (Of course lately all I can notice is the horrific smell from the A/C unit after I shut it off, smells like mold & then some :ph34r: ) NefCanuck Loss Of Some Coolant From Recovery Tank - NefCanuck - 06-16-2006 hardk0re,Jun 14 2006, 11:01 PM Wrote:Check it after a while, it will probably go back up where its supposed to be. Checked it this morning before I left for work, still at the same point as it was last night, halfway between MAX & MIN NefCanuck Loss Of Some Coolant From Recovery Tank - Burnin21 - 06-16-2006 That happened to me Nef, I just topped it up with Water and havnt had a problem since lol. Loss Of Some Coolant From Recovery Tank - Fingers - 06-24-2006 Keep in mind, that the engine temperature dictates how high the level in the recovery tank is. Maybe when you first checked it, the rad was still hot. Loss Of Some Coolant From Recovery Tank - NefCanuck - 06-25-2006 Fingers,Jun 23 2006, 11:06 PM Wrote:Keep in mind, that the engine temperature dictates how high the level in the recovery tank is. Maybe when you first checked it, the rad was still hot. Nope I've checked it when stone cold (12 hours sat) still down, keeping an eye on it... NefCanuck |
