Udp Belt Size? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Udp Belt Size? (/showthread.php?tid=9475) |
Udp Belt Size? - Casper - 06-01-2006 Just got a UDP, but it came with a belt intended for a car WITH A/C. Mine doesn't have it, so I need a shorter belt... Problem is, everywhere I look, I can only get part numbers for the longer units for cars with A/C. Does anybody know either the length or a PN for this? Udp Belt Size? - NOS2Go4Me - 06-06-2006 It really depends on the part manufacturer for the UDP (set). How many pulleys? The overall expected decrease in belt length as reported by the UDP manufacturer? The reason I say that is because I had the same experience. I had the wrong length from EscortFocus.com... they told em the right length, which was too short. GRRR. I ended up going longer than expected to get the proper tension on the belt itself. You might have to measure the stock belt, deduct the amount expected, and then buy a few belts in .25" and .5" increments to see which one fits. Return the ones that don't. Udp Belt Size? - Casper - 06-06-2006 Bando 6PK1905 Dayco 5060750 Ended up getting the part numbers from Tony @ New Edge last week, and I installed my MAC UDP on the weekend. Actually, 99% of crank UDPs are all 4" in diameter, so the belt size is somewhat universal. The tensioner will take up the rest of the slack. |
