Disabling Drl On 2006 Focus - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Disabling Drl On 2006 Focus (/showthread.php?tid=9560) |
Disabling Drl On 2006 Focus - cowymo - 05-26-2006 Does anyone knows which relay to remove to disable the DRL on a 2006?? Disabling Drl On 2006 Focus - guilty - 05-26-2006 Not sure which one exactly, but it's probably different on the 06s anyway. It should be in your owners manual under fuses/relays though. Disabling Drl On 2006 Focus - cowymo - 05-26-2006 guilty,May 26 2006, 12:03 AM Wrote:Not sure which one exactly, but it's probably different on the 06s anyway. It should be in your owners manual under fuses/relays though. so am i safe to say I will disable the DRL once I pull out the relay?? Disabling Drl On 2006 Focus - NOS2Go4Me - 05-26-2006 Yes. Re-route it to the fogs. It looks much better :D Disabling Drl On 2006 Focus - Crazirich - 05-26-2006 I pulled my drl relay.... #R12 worked fine... Disabling Drl On 2006 Focus - cowymo - 05-27-2006 I pull out my DRL relay today.. Such a pain to get to the fuse box.. 03 was so much easier under the hood.. |
