The Rim I Wanted Not Available, Need Your Help! - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Appearance (//www.focuscanada.net/forum/forumdisplay.php?fid=21) +--- Thread: The Rim I Wanted Not Available, Need Your Help! (/showthread.php?tid=9561) |
The Rim I Wanted Not Available, Need Your Help! - nass - 05-26-2006 As you may remember from my other thread I was going to get the Excel E-2 rim. I Called up Wheel Max and they said they don't have any stock on this and they can't order this rim because it's "special" Here is where your collective powers come into play. If you've seen a rim that's similar to the one below let me know please :) or if you know any other place to buy Excel wheels that would be stellar as well. Thanks! ![]() The Rim I Wanted Not Available, Need Your Help! - guilty - 05-26-2006 Check out BBS wheels.. I thought that's where that company stole the design from. The Rim I Wanted Not Available, Need Your Help! - mo_focus - 05-26-2006 http://www.tirerack.com/wheels/DisplayWhee...elFinish=Plasma http://www.tirerack.com/wheels/DisplayWhee...ht+Silver+Paint http://www.tirerack.com/wheels/DisplayWhee...%2FMachined+Lip here are couple for you. you can always ask them not to drill the holes for you so it can be custom drilled. good luck The Rim I Wanted Not Available, Need Your Help! - FocusGuy7476 - 05-26-2006 guilty,May 25 2006, 09:27 PM Wrote:Check out BBS wheels.. I thought that's where that company stole the design from. should take out a loan if he wants BBS wheels, and I think they only make a 16" rim that fits the focus. The Rim I Wanted Not Available, Need Your Help! - nass - 05-26-2006 Thanks mo, those are close for sure. BBS sure are expensive and for my case not worth it. For that kinda money might as well go with OZ and make DP happy :) Can you get any rim as a blank and custom drill the holes to suit your application? Maybe I'll ask wheelmax if they can do that cause they have almost every other bolt pattern and size :( The Rim I Wanted Not Available, Need Your Help! - NOS2Go4Me - 05-29-2006 If you want that many spokes, what about 17" EAP SVT wheels from the FRPP catalog? |
