Rs Fuel Pump
Does anyone know where to get a Focus RS Fuel Pump or a part # of one?
Would you know the pumps capabilities? (Flow rate in LPH or GPM)
Thanks
~ DECEASED ~
The Z-ed Sled ('03 ZTW)
-Eibech Pro Kit
-17" SVT Euro's
-Tip & Tint for show
-nothing for go...yet!
Europe.
Expect to pay LOTS.
White 2001 ZX3
My Focus
My Photography
RS pump spec 255 lph , tank capacity 55l.
Keep in mind the rs fuel system is return type not returnless like NA spec focus, so you can't just swap the fuel pump . You will need the whole set up .The cheapest way is just get an svt pump it is good for 300+fwhp, if you need more just add boost a pump from kenny bell and you should be good for 350+fwhp B)
just get a walboro pump that is good for atleast 255lph i believe .. you can usually find them pretty cheap then just adapt it to the stock pick-up inside the tank
Walboro pumps are not designed for returnless systems unless they started making them recently...
SVT pump is the way to go...
  03-04 hi-flow fuel pump part #? NOS2Go4Me 3 2,491 08-26-2012, 09:50 PM
Last Post: shadowzx3
