Ok, So I have been having an on going argument with my boss at work b/c of focus wheel nuts. He claims that when we put steel wheels on a car that had aluminum wheels we have to change the nuts to the non exposed ones that arent chrome capped. He says that they had a car's wheel fall off b/c of the taper on the capped nuts being wrong for the steelies. Where I worked before I have put many sets of steel wheels on foci and never had a problem. The tech we used to have here "never did anything wrong and was never doubted when he worked here" just didnt want to admit he failed to tourque the wheels. Now that he is gone we are seeing soo many things that he had brainwashed everyone here come to the table and this is one of them. Now what I would like to know is if any body out there using steel wheels has ever been fed this line of b/s before. I have compared the nuts and the only difference in the nuts is the length. I even showed him the two nuts and he still wont let it go. Thanks for the info boys...
Wheel Nuts
I put my winter tires and steel rims on the car on October 30th. So far, they haven't fallen off and I used the nuts off of the aluminum rims
2000 White ZTS: retired 2012 Frosted Glass SEL: active K&N Filter.....
04-05-2007, 04:35 AM
oldeguy,Apr 4 2007, 01:12 PM Wrote:I put my winter tires and steel rims on the car on October 30th. So far, they haven't fallen off and I used the nuts off of the aluminum rims X2
04-05-2007, 05:17 AM
I switch between my stock 15" rims and the 17" svt rims and all i use are the alluminums lugs and 1 locking lug per wheel. No problems ever.
09 F150 SCREW 4X4 XTR Former Show Hella Magic Module Tail Lights, 17" Ford Racing EAP rims, 5% Rear, 20% Front Tint, Panasonic CQ7401 Deck, 2 MB Quart 10's, Alpine Components, Phoenix Gold 500.1 Amp Go Steeda Cold Ram Air Intake MBRP Exhaust (Gen 2), FK Coilovers, Hedman Header (Install Pending),FC Hi-Flo Cat (Install Pending),EBC Greenstuff Pads
04-05-2007, 05:25 AM
snorcus,Apr 4 2007, 02:09 PM Wrote:He says that they had a car's wheel fall off b/c of the taper on the capped nuts being wrong for the steelies. [right][snapback]233222[/snapback][/right]I think this is the key statement ... if the steel wheel and the alloy wheel have the same type of taper where the nut meets the wheel (and they might not) then you could use the same nuts ... but if the steel wheel was different, then you'd have to use a different style nut ... I don't think it makes any difference though whether or not the nut is capped just as long as the nut is long enough to seat properly.
04-05-2007, 05:44 AM
ZTWsquared,Apr 4 2007, 07:25 PM Wrote:snorcus,Apr 4 2007, 02:09 PM Wrote:He says that they had a car's wheel fall offÃÂ b/c of the taper on the capped nuts being wrong for the steelies. [right][snapback]233222[/snapback][/right]I think this is the key statement ... if the steel wheel and the alloy wheel have the same type of taper where the nut meets the wheel (and they might not) then you could use the same nuts ... but if the steel wheel was different, then you'd have to use a different style nut ... I don't think it makes any difference though whether or not the nut is capped just as long as the nut is long enough to seat properly. Exactly. The only other issue that may occur, is that if it were an aluminum rim, it's suggested to get them re-torqued after a few hundred kilometers. It has been known that the nut may back seat a small amount.
04-05-2007, 06:24 AM
vy_MR2,Apr 4 2007, 03:44 PM Wrote:Re-torquing your wheel nuts, should be done after 100 kms or so everytime you take off a rim, if you are a do-it yourselferZTWsquared,Apr 4 2007, 07:25 PM Wrote:snorcus,Apr 4 2007, 02:09 PM Wrote:He says that they had a car's wheel fall off b/c of the taper on the capped nuts being wrong for the steelies. [right][snapback]233222[/snapback][/right]I think this is the key statement ... if the steel wheel and the alloy wheel have the same type of taper where the nut meets the wheel (and they might not) then you could use the same nuts ... but if the steel wheel was different, then you'd have to use a different style nut ... I don't think it makes any difference though whether or not the nut is capped just as long as the nut is long enough to seat properly.
04-05-2007, 09:40 AM
16" Ford Aloys + 14" Ford Steelies + Same nuts year round = No Problems for 2 winters.
I do check them every month or so, to be sure they are tight.
2008 Taurus X to be modded. 2002 ZX5 parted out. Forever known as the "SLOCUS". 2010 Dyno #'s 102.96HP/105.84TQ 2011 Dyno #'s 111.44HP/115.17TQ Still The Weakest Link ![]() Dial 1-800-AUTO-PARTS for your local speed shop.
04-05-2007, 10:23 AM
ZTWsquared is exactly right.
As for the aluminum wheels I always do that , torque them , drive a little , re-torque.
04-05-2007, 11:01 AM
I've never had any problems either
04-05-2007, 02:56 PM
wow man sounds llike your bose does lines off the water cooler
![]() I could List my mods.. my times and even my future mods here.. but there the same as yours.. with a little less conversation and a lot more action!
04-05-2007, 03:04 PM
ZED_not_zee,Apr 4 2007, 11:56 PM Wrote:wow man sounds llike your bose does lines off the water coolerhaha nicely put
04-05-2007, 11:19 PM
Hes a good guy just clueless when it comes to cars, which is funny cause he is the fixed ops manager at a car dealership. Thanks for the replies .
04-06-2007, 08:23 AM
Never had a problem yet. One winter with the stocker nuts, one winter with the aluminum nuts.
33" BFG Mud-Terrain KM2s, lots of Rough Country gear - bumper, 2.5" lift, swaybar disconnects, Superwinch 10,000lb winch, Detroit Locker in rear D44 axle, custom exhaust, K+N filtercharger, Superchips-tuned. Daily driver 2: 2006 Subaru Legacy GT COBB Stage 1+ package - AccessPort tuner, COBB intake and airbox. Stage 2 coming shortly - COBB 3" AT stainless DP and race cat, custom 3" Magnaflow-based exhaust and Stage 2 COBB tune. |
« Next Oldest | Next Newest »
Locking Wheel Nuts For 04 Svt | SVTmonkey | 6 | 2,520 |
11-22-2004, 09:51 AM Last Post: SVTmonkey |
