Help
Yesterday, Driving Home, With the System Pounding I started to Bog out and the Volts dropped out...
I pulled the car over, Lifted the Hood and BAM The 4G Alt wire is on fire...
So i blew the Fire out(Should have just walked away I know)
And looked at the damage.
The Wire was resting Here, And shorted out, At the same time Burned a Hole through the Pipe.
[Image: shrink_egrvalvewithPaint.jpg]
I fixed the Pipe, Ran a New 6gauge Wire from the Alt to the Batt, And started the Car.
Now the Car idles Like a Bag of s***.
Volts are outa wacked a bit, But the Idle drops to 700-500rpm...
No codes yet(SCT might be blocking them)
Need Help.
Blown Alt?
Screwed Computer?
Battery holds a charge.
That is because of the pipe it burned , how did you fix it ?
Ford Focus SES ZX5
TEAM DURATEC # 99
Exhaust Tape
Tape? You might want to get some JB Weld or something on that..... not tape......
I just had that problem too....you have to change that wire which is a pain in the ass to do because it runs in with your harness
Its Not Just Tape, Its aluminum.
REDZX3
So you think its the New Wire i put in?
Its a heavey Duty wire, But at the same time its only a 12 count copper, To make a 6 gauge size.
I would replace the wire again with the same count as the factory wire... anything thicker would cause more of a current and problems. Once I replaced mine everything has been fine.
