Long Tube Header - Heat Shield
So I was bored allot today, still working on the tune for my car with Randy so i've spent way too much time thinking of stuff to do that didn't cost anything...also being broke :P
Made up this heat shield for the header, I think it should help stop some of the heat comming up from the headers since my intake is right above the engine.
[Image: header_cover.jpg]
aren't your headers wrapped already?
I'd go without the heat shield .. looks alot better when you can see the headers
Below Average Car Club
still radiates a ton of heat, even wrapped and ceramic coated.
I like it. It matches my floor mats. :D
It would look good in my car too. Hardkore, are you getting the hint?
2000 White ZTS: retired
2012 Frosted Glass SEL: active
K&N Filter.....
what is that big log right behind the cone filter?
naz,Jun 8 2007, 01:37 PM Wrote:what is that big log right behind the cone filter?
[right][snapback]240932[/snapback][/right]
PWR intercooler barrel.
[right][snapback]240946[/snapback][/right]
that is really interesting! how does it work? I'm used to IC have fins and stuff and looking more like
[Image: 112_0306_Engz_Road_Test+2003_Prodrive_Su...e_View.jpg]
is that an air/water IC?
It is air/water. I've got the 8" IC barrel, then a pump that pumps the coolant/water mix from a resevoir through a front mount heat exchanger and up through the barrel and back into the resevoir.
looks good and it keeps heat down good job .
Ford Focus SES ZX5
Blue Underglow, Clear Corners, Shorty antenna, vogtland springs , Rust Module,Truebendz 2.5 ss magnaflow and Fuzion 205/50/16 HRI's
TEAM DURATEC # 99
The only sad part of that setup is that your air filter is way uptop and inhaling lots of heat...
Unless you have a hood scoop to feed it fresher air?
P.S. ... I'd still like to have that setup anytime :P
2007 CD Silver ST  **** FOR SALE ****
2014 Performance Blue ST  **** SOLD ****
2016 Ford Edge Sport Shadow Black
  Shorty Header Heat Problem qtgino 15 4,151 09-22-2004, 12:30 PM
Last Post: Blackzx3
Users browsing this thread: 4 Guest(s)
