Stock Bulbs
How many watts are the stock headlights and foglights?
Any one know?
Mason,Jul 18 2007, 02:07 PM Wrote:How many watts are the stock headlights and foglights?
Any one know?
[right][snapback]244313[/snapback][/right]
I believe 55 for the headlights, not sure about the fogs
I am picking up a set this weekend. I will let you know when I install them.
35w
konafocuswrc,Jul 19 2007, 09:14 PM Wrote:35w
[right][snapback]244450[/snapback][/right]
I figured they were around 40 on the headlights. Fogs would be close.
Wondered cause I ordered Fogs and headlights in 65watt bulbs.
Should be brighter.
Stock watts on headlights are 55/65 - 55 low beam, 65 high beam, and I think the 35 watts mentioned above is correct for foglights.
But to be clear (no pun intended) these numbers only represent the current the bulbs draw ... they don't necessarily indicate their light output which would more correctly be measured in lumens.
One thing that is constant, however is the higher the watts the higher the heat.
Getting fogs at considerably more than 35 watts I believe could create a fire risk, as the entire wiring harness, connectors, plugs, switches, etc etc, would all be configured for just 35 watts. If you're upping the fogs to 65 watts you should seriously consider installing a new circuit straight to the battery, using the OE current to trigger a relay.
Should be brighter.
[right][snapback]244508[/snapback][/right]
I emailed the company today. The headlights are 65. Fogs are 45.
They are a Direct replacement for stock bulbs and no modification is required.
They were very detailed in there answer. Kinda Nice
