Threads: 9
Would 6 degrees of adjustibility be enough with cam gears? I have seen some cam geas with 12. I will be using the car as a daily driver still. I have most of the add-ons that you can get and just waiting til spring to add my Crower stage 2. Any help would be appreciated.
Thanks
Mark
Threads: 5
i would assume that would be enough...i just got in a cam gear for my budies heavily modified NA golf, and it has 8 degrees...
-Will update mods when its all put back together...
1998 nissan 200sx 2.0L Turbo
Check it out here
Threads: 84
well, i'll assume you are speaking of the Kents...
the most important thing about cam gears is how many adjust bolts they have.
if they have less than 4 bolts don't even look at them. the gears with the most adjuster bolts are always going to be the best! FC, Kent, FR and Esslinger are the best imho!
the amount of adjustment will only become an issue if you perfectly degree your cams.
