First Drive Review Azenis Sport Rt615
so i got the RT615s in 225/50/16 mounted on my sube this weekend and i've put about 100 miles of light street use on them, and here are my first impressions (keep in mind i'm coming from a set of similar size kumho MX)
sidewall stiffness: wow. these tires much stiff sidewalls than the kumhos. nothing has changed about my car other than the tires and bumps and other vibrations are much more noticeable now. turn in feels a bit more direct as well. the RT615 remind me a lot of the RT215 in terms of sidewall (stiff!)
grip: this one is a question mark since i can't come anywhere close to the traction limit of either the MX or the RT615 on the street. i'm expecting the azenis to have more grip, since they pick up a lot more debris on the rubber than the kumho (so at least they LOOK sticky). i'm going to the circuit in a few weeks, so i'll update with more info then. the MX were not very heat sensitive, so i'm slightly concerned that the RT615 have more grip at the expense of heat sensitivity.. we'll see
some qualitative notes:
- the tread does not look like it will be very effective at evacuating standing water. i will have to take it easy around standing water.. just like the RT215s
- the tires seem less noise than the MX
- it doesn't make sense to get anything more aggressive than this for street use.
UPDATE:
drove on these for a few hundred street miles and i am impressed. the sidewalls are stiff and there is a substantial amount of dry grip (more than kumho mx)
i highly recommend this tire for users looking for max dry grip at a low cost. i've driven r compound equipped cars on the street and the RT615 feel very similar. i know there is less outright grip than on a r tire, but i can't tell on the street. i run out of guts (i am afraid of hitting a pedestrian or getting a ticket) well before i run out of grip in my daily driving
UPDATE2: drove these tires in heavy rain, no standing water. awesome! great wet grip.. anyone who says RT615 are not good in the rain have either not used them, used them with too little tread, or hit a massive amount of standing water at high speeds
in a wet corner i actually heard the tires scrabbling for grip.. no squeal, no sidewall rolling over.. just tires clawing for grip + awd fairies combining for awesome wet corner exit
ppl looking for a max grip street tire... buy these!!! they rock.
  Dunlop Direzza Sport Z1 Star Spec, Opinions/review Gabriel 27 16,786 05-05-2009, 01:59 PM
Last Post: Gabriel
