Got A Problem
My 2000 sedan with the spi motor, when ever its wet it likes to studder real bad at idle and also if i turn the heat or any temp of air it studders at idle. Any ideas.
Wires?
Vacuum Leak?
Ignition coil?
alternator?
ANTHONYD,Apr 29 2008, 10:56 AM Wrote:alternator?
[right][snapback]263205[/snapback][/right]
If it was the alternator would I be losing power in everything?
[right][snapback]263273[/snapback][/right]
could be the Voltage regulator within the alternator. But, I remember a couple of guys who had, the SPI having troubles with the coil pack.
the POS shadow that I used to have got the same problem, the tow truck driver told me it is the plug wire and he is right.
260000km and counting.....
