Threads: 58
Hey Everyone. I noticed I had a small leak somewhere dripping in the snow when I put the car in the garage. Anyone know what pressure the system needs to be to check it.
DRyanC
2000 Black ZX3 (sold)
2007 CD Silver ZXW ses
Threads: 69
It could be a cracked thermostat housing. It's a common problem with the zetec. You will probably see only a few drops from roughly around the area of where the transmission meets the engine.
The part is about $75 from Ford and takes about an hour to do yourself.
Link to fix instructions
Threads: 58
Thanks guys. I have a pressure tester. I only pumped it up to 10 pounds last night, like I said I didn't know what the system runs at. The first time I pumped it to 10psi it drop to 5 in about 20 min. so I pumped it back to 10 and it never moved. I will try 18 tonight. I guess 10 psi is not enough to move the coolant out of the leak.
DRyanC
Threads: 269
5
My T-stat housing has been replaced twice since I have had the car. It would be a good place to start.
Still The Weakest Link![Blush Blush](//www.focuscanada.net/forum/images/smilies/blush.gif)
Threads: 305
9
My money is cracked tstat housing.
Threads: 215
Just did my tstat last month, its fairly easy to see if you are leaking enoigh
Threads: 96
10psi should be plenty ... if you put to much pressure in the system you can make things leak that normally wouldn't under regular pressure .. and you also run the risk of having your heater core break due to having to much pressure in the system.
put a piece of cardboard down under the car and that way you can tell where the leak is coming from
Threads: 58
I haven't had a chance to look over everything again, hopefully tonight.
DRyanC
