Stripping, Painting, And Installing Zx3 Skirts
QWKRN-U,Feb 28 2009, 09: Wrote:Try not to use too coarse of sand paper on your skirts, it will turn the plastic "furry" when you try to prime it. I would use 220-240grit paper to feather out the chips and scratches, as long as the rest of the paint is in good shape and not pealing or anything I would just scuff it with 320 and prime it. For primer use Plastic coat  grey self etching primer, I find it works very well for a rattle can primer. Ill try and get a part # for the primer. Then scuff them with 400-600 grit paper and top coat them.
[right][snapback]281884[/snapback][/right]
That was the info I was looking for. Thanks man!
NP man, glad I could help. Thats what I do for living. Ill get the part # for that primer tomorrow when Im at work. I highly recomend you give it a try.
The part # is 470 and its Plasti-kote grey etching primer. I get it from NAPA, not sure if CT sells it or not.
Lol he works at NAPA.
LMAO that should make it pretty easy to get. :lol:
LOL I used to work at NAPA. Now I work for Castrol. But I still have my connections. Well I have started on the prep and things are going well. Slow but well. I am hand sanding everything and the 3M paper seems to be getting clogged up quickly. Although by bending the paper it just falls off. Here is my progress so far.
Before
[Image: PICT0001.jpg]
[Image: PICT0002.jpg]
After
[Image: PICT0004.jpg]
[Image: PICT0005.jpg]
I do have a lot more to do but it is coming along nicely. I should be able to get these on at some point this spring if everything goes as planned.
i have that exact side skirts pulled out from my car..
non painted...it is missing front portion..
you can pick it up if you want to..
konafocuswrc,Mar 8 2009, 06:43 PM Wrote:i have that exact side skirts pulled out from my car..
[right][snapback]282307[/snapback][/right]
You have a pair of skirts for a ZX3 that aren't painted, only missing the front caps? I feel like I just wasted an afternoon sanding. I will take them! Where are you located? Markham or something right?
I'm pretty sure you'd still have to sand them as they have a texture to them that would have to be smoothed down before painting
but still easier to sand down textures..
i m in toronto king + dufferin..or etobicoke sherway garden..
QWKRN-U,Feb 28 2009, 09: Wrote:Try not to use too coarse of sand paper on your skirts, it will turn the plastic &quot;furry&quot; when you try to prime it. I would use 220-240grit paper to feather out the chips and scratches, as long as the rest of the paint is in good shape and not pealing or anything I would just scuff it with 320 and prime it. For primer use Plastic coat&nbsp; grey self etching primer, I find it works very well for a rattle can primer. Ill try and get a part # for the primer. Then scuff them with 400-600 grit paper and top coat them.
This guys advice...............right on the $$$
Thanks mefordf4u. Keep us updated with pics, even if you use the other skirts. Your doin a fine job on the yellow ones though.
Can you save some time by renting a hand-sander from Home Depot? Or would that sander be too rough on the skirt? Just trying to find a way that would make it easier for you.
Yup a dual action palm sander would work, they are fairly cheap too under $40.
