10-26-2009, 02:44 AM
Hey guys, I was wondering if battery cables were covered under the Ford warranty? They are closed today so I can't call to ask. My car wouldn't start today so I noticed my positive contact was pretty covered in corrosion so I cleaned it all up and put it back on and car started fine. But the positive cable contact doesn't seat on the battery tight at all...it's a lil loose even when tightened right down so I think the positive contact on the cable got corroded down so it doesn't fit right anymore. The battery contacts look fine. I also noticed down the wire a bit, some of the rubber is burned off.
