Threads: 58
Hey everyone again, thanks for your last help, now I have another problem.
2000 Focus ZX3 auto
My problem: The car starts great now, but now after driving for a bit and I put the car in N or P sometimes it stalls out, sometime it almost stalls, and sometimes it's fine. The idle only drops in P and N, D and R are fine, the idle kicks up when you put it in D or R. Where should I look first. I have no problems mechanically it's just my diagnosing skills are weak.
thanks in advance.
DRyanC
2000 Black ZX3 (sold)
2007 CD Silver ZXW ses
Threads: 291
4
idle should go up a bit in p or n, i didn't say porn..
Threads: 58
Well I was at Crappy tire and pick up a set off plug to start. This is my 4th set. only have 120,000 on it
DRyanC
Threads: 381
shouldn't plugs be good for at elast 50k?
Threads: 80
plug wires instead?
loose/bad ground?
DPFE?
Threads: 72
What plugs are you running?
![[Image: 49951.png]](http://www.fuelly.com/sig-metric/49951.png)
Threads: 58
Well I started with the plug, I'll see if I get a call from the wife today. I had Bosch platinum in it. I know they were replace once when the car was under the 3/60,000, then I changed them maybe 3, maybe 4 years ago, but that's only 30-40,000km. I thought platinum plug are like 100,000, no?
Another question, Focushacks has 49ft/# for the rear spindle nut for the drum, is this correct? (if anyone catches this)
DRyanC
Threads: 72
12-10-2009, 01:06 AM
(This post was last modified: 12-10-2009, 01:07 AM by reldridge.)
I know Foci don't like the Bosch Platinum stuff. If you're going to replace, use stock Motorcraft ones from Ford, unless you are boosted.
49 ft/lb for the nut that holds the drum onto the spindle? I thought it was way more than that (like over 180 ft/lbs).
Threads: 58
that's what I thought. I know I didn't loosen a nut that was tightened that much, it was pretty much 2 fingers on a bar to loosen. I did put them on tighter than they came off but not 180.
DRyanC
Threads: 58
Well, one I know the dealer had off for service, the other hasn't been removed since assembled on the line.
DRyanC
