question
ive been looking all over the site for instructions but i have no idea what to do. im looking to remove my daytime running lights? i own a 07 focus.
pull fuse for them. the 00-04 you can make a jumper for it to work and turn em to fog lights, but on 05-07 you have to remove fuse and 08+ you cant do it at all
any idea which fuse? i tried checking the manual but it didnt help at all. does the foglight drl mod work for 07?
(05-28-2010, 03:26 AM)gfxfocus Wrote: any idea which fuse? i tried checking the manual but it didnt help at all. does the foglight drl mod work for 07?
No, only the 00-04's. As for the fuse, check under the cover for the fuse panel and it should say which fuse is for the DRL's.
i think on focusfanatics or focaljet there's instructions for 'Daytime Running Lights mod' or 'DRL mod'.
the DRL fuse is inside the cabin under the dash, i believe it is fuse #46 should be a blue one. check the manual again its in there.
