Poll: Will it help performance.
Yes
No
May be
[Show Results]
04 WRX STi Hood scoop
#21
At least it's functional....
Would look better with painted mirror caps and a set of Hella projectors
2002 pitch black ZX3
__________________
Mach HIDs, 02 RS upper grille, Cervini's body kit, DTM drop mirrors, D2 coilovers, purple focussport strut tower bar and chrome rear bar, purple FC tb, Powerworks supercharger, optima yellow top, SVT ceramic coated header,Random Tech SVT/Zetec hi-flow cat , bosal flex, vibrant cat back with custom dual tips, b&m short throw shifter, pro-fit fuel door, shorty antenna, race-pedals.com "focus" pedals, clear 3rd brake light, SVT hvac controls, Transfer Racing billet hvac knobs, RS shift knob, RS Sparco E-brake handle, Mazda3 rear wiper, CarZone 3 piece roof wing, 17" Keskin KT4 wheels
Classic Painting
Your scoop is not my cup of tea based solely on its visual appearance and proportion; however, I like the functionality and the workmanship and I applaud you for both.
I think you are absolutely right in wanting to reduce underhood temps, but having said that, the real problem with the JRSC BBK is in fact the high intake air temperatures created by the blower itself and it's effect on timing retardation; and cooling the outside of the blower won't cure that problem.
The solution to the problem is to ensure the air coming into and through the snorkel and filter is as cool as possible to begin with, and then cooling it at the source of the problem which is inside the blower case.
To do that I wrapped the SVT headers, I insulated the entire intake plumbing tract, and I installed a water meth injection system. Not only does it lower the IAT significantly right at the point of entry into the cylinders, it also seriously increases the effective octane rating (even with 87 in the tank) - both of which can allow you to tune for quite a bit more power.
I may yet install a vent in the hood, but that's more for the hood's sake after a long run at the track. With the setup mentioned above, I was able to maintain full power throughout a 30 minute run at basically full throttle and top speeds approaching 200 kph. I don't think a hood scoop could have done that, and even worse, I think it would add drag.
Just my .02
It actually doesn't look that bad, at least your a boosted focus so you've got some power behind you...
  Hood Scoop Deal! (need Your Opinions On The Look) NikiterZTS 37 10,915 04-18-2007, 11:46 AM
Last Post: audionut405
Users browsing this thread: 27 Guest(s)
