07 zx3... Where to start???
^ they must of messed up then because they are all the same LOL
all hatchback exhaust fit eachother, all sedan/coupe exhausts are interchangeable and all wagon systems are the same at one another
So I've been thinking about getting a turbo some more and I've decided I'm gonna wait atleast a year or two before I put one one! I've decided to keep it n/a for the time being. That being said, still planning on picking up a c-f-m 67mm tb and a steeda Sri to compliment it.
Also, I'm fairly certain I've decided to go with the steeda sts opposed to the c-f-m sts.
As for suspension, I'm pretty sure I'm gonna be purchasing an frpp full kit with the frpp springs. Was told they're a little stiff, but for the price I think I can handle it as a dd. Also, thinking about an eibach anti roll sway kit. Think it would be a big upgrade over the stock sway bar
http://focus.c-f-m.com/eibachanti-rollsw...focus.aspx
Have more plans for n/a engine mods just actually getting tired now, so should take advantage of it!
I support you 100% on your FRPP choice. Far superior to the Eibach Pro-Kit. Yes it is stiff but you'll love it. By far the best suspension I have used.
I use the FRPP susp kit on mine as well. I only find it slightly stiffer than the stock suspension, most notably on manhole covers,ruts and potholes. However, when it gets twisty that's where it shines car stays nice and stable around corners, far less body roll. I recently added the Steeda 22mm swaybar and now it just digs in like crazy around corners. Way less understeer.
steeda 30mm rear sway bar = sex for ur handling
Users browsing this thread: 17 Guest(s)
