Threads: 313
21
... install these fricken H7 bulbs in my MACH headlight assemblies.
H7 bulb connector
This is what the mounting point looks like (shouldn't there be a wire clip attached to one of these screws?)
This is bulb connector with metal clip attached
And this is the metal clip removed from the bulb connector.
Threads: 149
Are those for the high beams? Because i know low beams are d2s
Threads: 313
21
(06-15-2011, 11:08 AM)GFXjamie Wrote: Are those for the high beams? Because i know low beams are d2s
Yeah no problem with the low beams (and yes D2S) ... H7s are indeed high beams and buried to one side in the housing - my hand doesn't even fit down there.
Threads: 143
Do you have the Ford Racing Hids? Or the Svt Hids? I know there shouldn't be a diiference, but they could have changed the bulb holder to accommodate the DRL function maybe? I know mine has a wire clip with a plastic bulb socket that are a huge pain to try and change
Threads: 313
21
(06-15-2011, 09:52 PM)SL8RZZX3 Wrote: Do you have the Ford Racing Hids? Or the Svt Hids? I know there shouldn't be a diiference, but they could have changed the bulb holder to accommodate the DRL function maybe? I know mine has a wire clip with a plastic bulb socket that are a huge pain to try and change
Even worse - they are the Depo knock-offs ... any idea Gord where I could get me some of those wire clips
Threads: 98
3
Why not grab just some wire and wrap it around the clip to each screw, then use a small ratchet with and extension and a screw driver bit to tighten?
