Broke A Front Wheel Stud!
damn.. I broke one of the front wheel stud when I was replacing the regular acorn nut with a lock nut. this sucks.. looks like i have to get my hands dirty to fix this.
has this happened to anyone here?
I'm just gonna follow this.
http://www.focushacks.com/index.php?modid=44
[Image: sig.jpg]
Stripped or broke as in snapped the stud itself? I would have thought that practically impossible. What were you torquing them to?
2001 ZTS,Mar 6 2005, 07:50 PM Wrote:Stripped or broke as in snapped the stud itself? I would have thought that practically impossible. What were you torquing them to?
[right][snapback]91716[/snapback][/right]
it actually broke off. this happened when I was removing the nut.
looks like its flush with the disc brake hub. so all i have to do is remove the disc brake and hammer it out. I might put an open ended nut and hammer on it.
[Image: sig.jpg]
I'd be having a chat with whoever rotated your wheels last. They obviously leaned on it with the airtools a bit too long.
2001 ZTS,Mar 6 2005, 08:03 PM Wrote:I'd be having a chat with whoever rotated your wheels last. They obviously leaned on it with the airtools a bit too long.
[right][snapback]91726[/snapback][/right]
that's probably what happened.. hopefully the other ones are ok. I usually install my own wheels for spring and summer change but I bought new tires for winter. Oh well..
[Image: sig.jpg]
Any one know the specs for the focus wheels studs.
I found these stronger studs.
ARP Wheel Studs
Moroso Wheel Studs
but don't know which one is for the focus.
[Image: sig.jpg]
After some research, this is what I found out.
The knurl size for the wheel stud for the front hub of focus is .625"; tread size is 12mm x 1.5
looks like the closest aftermarket stud that can be used is the ARP .625" knurl; 1/2''-20 tread size. part# 070-100-7703 $9.99US per set of 5 from Jeg's. hole for the disc brake hub probably needs to be enlarged a little bit and new set of bolts with 1/2"-20 tread measurement is required.
As for my solution, I'll probably just go to the dealer and grab 2-3 wheel studs and replace the broken one and keep the other 2 in case I break some more.
[Image: sig.jpg]
when i was working on a honda, i snapped 4 of the 16 wheel studs on the car...honda = poor quality bolts...very easy to fix that problem though
-Will update mods when its all put back together...
1998 nissan 200sx 2.0L Turbo
Check it out here
Problem fixed.
I went to Ford and bought 3 wheel studs thinking that I will probably need it in the future. they only cost $5.70 each so it's no biggy. I went to my shop, remove my wheel and replace the broken stud and also replaced another one that has 1/4" of the tip broken off. Good thing I got extras. Labour only cost me $20 cash, which is very cheap.
[Image: sig.jpg]
  rattle / wobble sound front right wheel zx3wantobesvt 9 4,431 08-26-2013, 01:50 PM
Last Post: VanFocus
  Front Wheel Stud Broken Zoom 9 3,872 11-26-2005, 09:23 AM
Last Post: meford4u
  Broken Wheel Stud schade 3 2,033 04-18-2005, 03:53 AM
Last Post: ZX3TUNR
